Question about Kohler Electrical Supplies
On a 350 kva kohler the generator whilst working cuts off and shows auxiliary fault light shows
Posted by Paul Harley on
sherlywang
    Master:
  • 425 Answers
I think you can ask your supplier, they most know their generator.
If you plan to have a new diesel generator set, maybe you can consider Cummins, Volvo, Perkins, as well as China made generator: Yuchai, Shangchai, Weichai, Ricardo etc.
Here is the website:
https://starlightgenerator.en.made-in-china.com/
Posted on Aug 23, 2019
3 Related Answers
Wayne Holden
  • 512 Answers
SOURCE: What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Problem solved by poster. good work!
Posted on Oct 08, 2012
Wayne Holden
  • 512 Answers
SOURCE: kohler 30rz62 generator auxiliary fault
Already solved.
Wayne Holden
  • 512 Answers
SOURCE: kohler generator 30rz62 auxiliary fault
Fourth time. Already solved.
Hi. I have a generator. Kholer. Once i load the voltage. Its shuting downg the it showing over voltage.
what you haven't mentioned is the capacity of the genset
( 500 kva , 1000 kva etc ) and the loads that you are applying ( fridge , tools lights stoves , etc) comment on this for a better answer
Oct 19, 2015 | Electrical Supplies
Generator had been running for 3 hours with a/c and refrigerator and lights (on concession trailer)when we experienced a loss
the unit has gone into over load
The total power requirement has exceed the output of the generator
for example if the generator is a 2.500 kw or kva then it will generate well at 1.8 kva or kw but it will not run forever at 2.5 kva -kw
When a ac is running the power requirement will be constant on the generator and with the fridge as well then the load will be at the maximum out put of the unit.
when the fridge starts again the extra load will exceed the max out put of the generator and it will slow down ( lights dimming ) and eventually go into overload mode
have an accredited electrician calculate your maximum load requirement for an external power supply and then get a unit that is at least 15.. kva kw better that required
generally fridges use 1000watts , ac conditions will draw over 3000watts and any thing else adds up . I am guessing that your generator is only 2500 unit
Apr 12, 2015 | Northstar Electrical Supplies
Generator starts but won't keep running
what are the fault indicators showing, over voltage, frequency wrong charging fault ?
Feb 11, 2015 | Kohler 13EGD 13kW Gasoline Marine Genset
Kohler 40EFOZD Auxiliary Lamp starts flashing After 2 minutes.
Make sure you have rated speed and voltage on the out put side.
Oct 13, 2014 | Kohler Electrical Supplies
WHAT IS THE MOST LIKELY CAUSE OF AN AUXILIARY FAULT ON A KOHLER GENERATOR MODEL 80ROZJ
Check radiator coolant fill right to the top, if it has a low level switch or faulty switch I have seen this
May 09, 2014 | Kohler Generator 30 Kw Nat Gas Or Propane...
How many watts would you get from a generator rated at 11hp and 5.8 kva. thanks
kva = kilo-volt-amps
watts = volts x amps = va
Therefore, 5.8kva = 5800 watts
Mar 24, 2010 | Honda 3000 Watt Portable Generator
Electrical Supplies Logo
130 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
