Question about Mustek Audio Players & Recorders
Mustek mp3 player green ivory...it says that is full memory but infact are only 2 songs on it. if i try to add new songs it says is full!!! please HELP!
Posted by silviaparada on
5 Related Answers
Anonymous
  • 27 Answers
SOURCE: i can't delete the songs and the computer says my mp3 is "full"
You need to be in MSC mode to do deletion in My Computer; put in MSC mode in the settings menu under USB, then plug in, go to My Computer and open it as a drive, go to Music folder and delete by rightclicking on songs and choosing delete. You can also format the player by rightclicking on the drive letter of the sansa and choosing format. If you are deleting from a program like Rhapsody (ugh) or windows media player, you will get a lot of issues and not all will delete. Stick with My Computer in MSC. Also as a side note, make sure you have all file folders showing including hidden files in the tools menu in My Computer
Posted on Oct 21, 2007
Anonymous
SOURCE: rca lyra won't read memory card
WMA files come in two formats DRM & non-DRM. Change your setting in Windows media player (Options - Copy Music) and re-rip the music CD. You can copy both versions but one will play but not the other.
Posted on Jan 18, 2008
Anonymous
SOURCE: youtopia model no. 68608 mp3 player
change the position of the hold button.
Posted on Apr 26, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: NWZ 615F Blk MP3 player
 “I can’t load any more songs into my mp3 player” or “An incorrect number of songs show up.” (MEMORY/FORMATTING ISSUE)
Sometimes, you can’t load any more songs into your player because, well, there just isn’t any more space left on your player.  Mp3 player product documentation does not actually list the actual amount of memory that you can use in your player, and it doesn’t list the actual number of songs that you can realistically fit on your player.  Every mp3 player needs a certain amount of memory space to operate and firmware upgrades decrease this available space – so, your 2GB mp3 player actually contains only 1.7 or 1.8 GB for music and other media files.  The mp3 player that says “can hold up to 1000 songs” may only hold 400 songs – the product documentation assumes that you are loading a 1-minute song in the lowest possible quality format – not very realistic.  A single 30-minute audiobook, speaker file, or video can seriously bring this number down.
Other times, however, you are experiencing a formatting issue or memory corruption.  If you plug your mp3 player into a computer that has an NTFS file system, and then plug it into a computer that has a FAT32 file system, you may experience this formatting issue (file system/formatting issue).  Similarly, this will happen if you plug an mp3 player into a computer running Windows Vista, and then plug it into a computer running Windows XP (operating system/formatting issue).  Or, if you plug your computer into a PC, and then into a MAC (PC or system/formatting issue).  Or, if you plug it into a computer with Windows Media Player 10, and then into a computer running Windows Media Player 11 (software/formatting issue).
Apparently, if you add too many folders, especially via Playlist, via Windows Media Player, the Mp3 player's file system will become unstable - it can only handle a certain number of additional folders. To resolve the issue:
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Now, when music is transferred, it will be placed in the root directory of the flash memory disregarding the folder structure and allowing all tracks to be seen.
This procedure was designed for Siren Mp3 players, but is applicable to many other Mp3 players. It is not a guaranteed fix for every Mp3 player and every error of this type, but it is certainly not a widely known or reported solution.
Before proceeding with a format or reformat of your mp3 player, check with the manufacturer first.  On many players, a format or reformat along the lines suggested here will override your mp3 player’s native formatting and render your player unusable.  Transcend’s T.Sonic player is especially susceptible to this problem, and should never be formatted.  Also, the instructions below are for Windows-based PCs, not for Macintosh.  There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in some cases by updating the player's firmware or reloading the firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Posted on Sep 14, 2008
SmartAviator
SmartAviator
  • 449 Answers
SOURCE: When USB is connect MP3 player does not display all songs
Try running scandisk, chkdsk or simila program or format it using FAT option.
Posted on Jul 20, 2009
Hi, I would be very thankful if you help me. I have a brand new Mp3 Memorex 8590 and have added around 50 songs and it shows when playing one song on the display 1 of 1, and once the song is over, the...
It seems your new mp3 player memory is already full, you need to delete other files or songs before you added another. If it is not yet full, try to delete and reinstall other songs. Be sure the file songs you added has no error on it.
That the only things you will do, the mp3 player operate normally and trouble come as you add new songs, don't overload it, as it's built in memory will fail.
Thanks for asking.
Jun 22, 2011 | Memorex MMP8590 MP3 Player
Hello, Am using Sansa c200 . am unable to delete songs which i hav copied into player. and even i cant see any songs on computer(my music folder was showing empty) .i even tried to format the disk ..but...
See this tip posted here on this site. It may explain what is going on. copy this address into a new window -- http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
If that does not work go here and download the Sandisk utility. http://kb.sandisk.com/app/answers/detail/a_id/156
Jan 16, 2010 | SanDisk Sansa c200 MP3 Player
Keeps deleteing aongs when I try to add new songs
Sorry but you have to format your mp3 player with connecting it into your PC.Then it will work. Thanks :)
Jan 01, 2010 | Coby MP-705 Digital Media Player
Deleting songs off mp3. Mp3 is full so i want to add more songs. So I need 2 delete so or all of my songs off my mp3. & i'm 14 so it gets boring havin 2 listen 2 the same songs that you don't even want...
try using windows media player to navigate thru the file on you mp3 player and delete the ones you dont like on it then use the media player again to sync the new ones onto it
Sep 20, 2009 | Samsung YP-U3 MP3 Player
Mp3
First scane your mp3 then try to remove song from your mp3 if remove then you add new songs.
Mar 16, 2008 | Audio Players & Recorders
Can't copy songs on to SD 2 gig Card in Sansa e250
the card shows up as a separate drive letter, remember that
when the card is in the player, look for the second drive letter in My Computer and add the songs to it not the first; yes the card will show up in your library on the player only after you have unplugged it and restarted the player.
Oct 18, 2007 | SanDisk Sansa e250 MP3 Player
Fatal error
The hold/lock is engaged
Oct 05, 2007 | iLO (2 GB) MP3 Player
Unable to find new songs on SD card
If your device is too full, it wont have enough room to create the music database for the new songs. Move some of your music off of the device onto the memory card. Try to keep about 10MB free for each GB of music you have. You can add to this question for further assistance. Best of Luck.
Sep 24, 2007 | SanDisk Sansa e260 MP3 Player
523 people viewed this question
Top Mustek Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
