Question about Carrier 38CKC042 Air Conditioner
My air conditioner will kick on but will stay on and not
Cooling off whole place like it use too.
once on, keeps running with little cooling off.
what is the problem?
  • 10,865 Answers
Hello. If you havn't had a technician check your unit in the last two years you should consider a service call where the refrigerant level and several other factors will be checked and examined. Be sure to go with an established professional.
The "normal" indoor design temp is 75 degrees @ 75% relative humidity. So your air conditioner may not be operating under the same humidity levels as you recall from the past. Some people actually think their air conditioner will cool their home down well below 75 degrees; but that is not how they are designed.
Posted on Aug 20, 2009
Testimonial: "someone suggested it could be the themostat? is that also your presumption?"
  • 3,267 Answers
The thermostat is not functional, therefore its not cutting off the compressor once the room air gets cooled to the temp setting of the thermostat, also the refrigerant gas may have leaked out some but not the entire refrigerant gas(freon, CF4, etc.), keeping the compressor running contentiously to come down to the set temp..............sodeep
Testimonial: "great, will need to replace themostat then?"
6ya staff
SOURCE:
Air conditioner takes long time to cool on my 2008 new beetle
You need to take your vehicle and get your system checked. You could have a clutch issue, low freon, compressor going bad, or a leak issue. All can cause the symptoms you are describing.
Semper Fi,
Z
Feb 15, 2018 | Heating & Cooling
My Ac window unit keeps freezing up
Either the evaporator (front coil) is clogged with dirt, or you need some refrigerant. If refrigerant is very low, only one corner of the evaporator will get cold. So cold in fact that it will freeze. Then no more air can pass through that section of the evaporator, and the refrigeration will take place a little past that point. That keeps repeating itself until the whole evaporator is froze up. Look at the evaporator when you first turn on the air conditioner and "feel" the evaporator with your hands. The cooling should take place evenly from top to bottom, left to right.
May 09, 2011 | Heating & Cooling
A/c runs cool for about 20 minutes and then does not cool anymore. keeps running but does not cool.
Is the compressor still running or has it kicked out? The normal problem is that the unit is low on freon and the compressor is not cooling because of this. If the compressor is kicking off an feels hot to the touch but the inside coil is sweating when the compressor kicked off the compressor is going bad. On an outside chance the thermostat can be going out if you turn it to off or all the way down you should hear an audible click and again when you turn it up normally its good if the click is audible. good luck
Aug 11, 2010 | Dometic Rooftop RV Air Conditioner
Compressor not kicking in on 'cool'; or ;dry'
Have you checked that the controls are not set to fan only? If you have lets go to the next step. All window A/C have thermal switch.. These thermal switch keeps the compressor from overheating. In the event that the compressor is overloading it would trip then click back on as the compressor cools down. Sometimes those switches go bad but the compressor is ok. They are mounted on the compressor themselves and accesable once the A/C unit cover has been opened.
Jul 07, 2010 | Whirlpool ACQ122XK Air Conditioner
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
The air conditioner is running fine but is not cooling
I have to ask this. If it's running fine, but not cooling, then it's really not running fine is it? ha-ha Sorry. Are you saying it's not cooling enough? Does compressor stay kicked in, or does it cut out early? Fan working o.k.? Give some more details and we'll see if we can help.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
My roof dometic roof top air conditioner runs but will not cool when the motor kicks on it goes right back off and will not cool
Check run capacitor, or in the compressor wire box, there should be a little black overload that might be weak or loose connection.
Aug 02, 2009 | Heating & Cooling
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
Fedders Window AC
You may have thermostat problems. If the blower and compresssor kicks on, that indicates their ok. If you have a two wire thermostat, you can tie those wires together to see if the unit will operate. BE SURE TO DISCONNECT POWER.
Aug 16, 2007 | Fedders X Chassis A6X08F2A Air Conditioner
Window air conditioner keeps kicking off.
is the fans running at all. you have a short some where. od you know how to use an ohm meter? let me know
May 10, 2007 | LG LB1200ER Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
243 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
