To
Steering Gear Bolt
90 Nm (66 ft. lbs.)
Jam Nut
75 Nm (55 ft. lbs.)
NUMBER: 19-001-01
GROUP:
Steering
DATE: Mar. 23, 2001
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 19-003-00 REV A, DATED OCTOBER 6, 2000 WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE PART NUMBER CHANGES AND ADDITIONAL MODEL YEAR.
WARNING: FAILURE TO ACHIEVE A MINIMUM TORQUE OF 100 NM (74 FT. LBS.) MAY RESULT IN THE ATTACHING BOLTS LOOSENING AND FRACTURING. THIS COULD RESULT IN A SUBSEQUENT LOSS OF
STEERING CONTROL. BENDING THE RETAINING TABS ALONE WILL NOT PREVENT THIS.
SUBJECT:
Loose
Steering
OVERVIEW:
This bulletin provides service procedures and parts information for the inner tie rod bushings.
MODELS:
1993 - **2001 ** (LH) Concorde/Intrepid/LHS/New Yorker/Vision/300M
SYMPTOM/CONDITION:
Loose feel or clunk in the
steering wheel as the wheel is moved from side to side.
DIAGNOSIS:
Observe the inner tie rod to
steering gear attaching point while moving the
steering wheel from side to side. If there is movement between the gear and inner tie rod, perform the Repair Procedure. If no movement is evident further diagnosis of the condition will be required.
DISCUSSION:
The inner tie rod bushings have previously been serviced with the tie rod assembly. This bulletin releases the parts, service procedures, and special tool necessary to service just the bushings. Subsequent service manuals will contain the Repair Procedure.
