Question about Mad Dog Multimedia MegaVault USB 2.0 External Drive Case
Installed a 500G hard drive in the 3.5" enclosure. It doesn't recognize it as a hard drive. How do I fix?
Posted by dmellstrom on
Anonymous
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 145 Answers
Make sure that your HD was installed properly in enclosure. Remove the cable then atached again.
Posted on Aug 20, 2009
Mdhd320 ue
This is an extarnal harddive from Iomega. When you don't get it recognized at your PC, there are 3 options :
1) Incorrect driver installed
2) Internal electronics of USB-enclosure defective
3) Internal harddisk in USB-enclosure is defective
Oct 10, 2013 | Computers & Internet
My external hd was in use when the power went out and came on . it was about 30 seconds. now my computer and ps3 will not recognize it . It is 2TB Masscool 3.5 SATA enclosure with a wd 2TB hd green. just...
The could be only two reasons for that problem with enclosure or hd. You need first figure out which one is the problem.
Plug the HD directly to the computer and see if computer can recognize it. If computer can recognize HD and you can access it then the problem with enclosure and something got burned when power got back. If you the enclosure still under warranty try to get replacement of if you electronic tinker you might try to fix it. If computer not able to recongnize HD and you can't access it from WIN then HD got fried. I would not recommend to store any important data on HD there is always a chance it will fail at some point.
Cheers, DS
Oct 25, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
I have a 500g Western digital my passport. I have owned it for almost a year now. It fell off my dress just now and is not working properly. My computer recognizes it's existence and tells me the device is...
Something mechanically has gone wrong with the disk-drive inside the enclosure.
Search online for a professional "data recovery service".
They can disassemble the enclosure, disassemble the disk-drive, and fix it just long-enough to copy your files (onto another disk or onto blank DVD-writable media). Not "inexpensive".
Then, you can use WD's "Customer Loyalty Program", i.e., prove that you previously purchased a WD product, and you'll get a discount on buying another WD product, if you purchase through their web-site (and pay for shipping).
Oct 11, 2010 | Western Digital Passport WDXML800UE...
My G-Drive 500GB will not power on
with you limited query there is only so much one cand advise to do.
1. check all electrical connections including your power strip.
2. Replace electric cord for drive with new one
3. Pull drive from enclosure and see if computer will recognize it internally.
4. If drive is recognized by computer and all electrical outlets and fittings are in good order, your case enclosure needs to be replaced.
Nov 28, 2009 | G-Technology G-DRIVE (90801201) 250 GB...
Have installed ide hard drive but it isn't being recognized by the CPU and the light is strobing continually.
Did you install the IDE drive _inside_ the VANTEC external drive,
or did you install the IDE drive _inside_ your desktop computer?
Did you set the MA(ster) / SL(ave) / C(able)S(elect) drive to the correct position?
Sep 19, 2009 | Vantec NexStar-3 External 3.5inch...
The Bios doesn´t recognize my Fujitsu Hard Disk Driveon a Compaq Presario 700 Laptop. ¿What i can do?
You need to identify where the problem is.
The simplest method would be to get a 2.5" external IDE enclosure.
Remove the drive from the laptop and install it into the enclosure.
Connect the enclosure to another PC or laptop that has USB 2.0
If the other computers can read the drive and you can access the data on it then the problem is with the laptop and these type of repairs can be expensive.
If however the drive CANNOT be read on other machines then you need to replace it as it has failed. Trying to recover data from the drive may be difficult
If this information was useful please click
Aug 16, 2009 | Fujitsu Mobile MHR2020AT 20 GB ATA-100...
Computer sees drive as Generic USB Device
Hi Brian, It certainly sounds like either your drive enclosure or the drive itself has some failed circuitry. You can try moving the drive into a new enclosure, if you're not sure how, take it to a local computer shop and have them transfer it into a new enclosure and test it for you. If it works in the new enclosure, you're done! If not reply back here by adding a comment with your country and city and I'll pass along a recommendation for somewhere to send the drive for data recovery. Chris
Jun 05, 2009 | Cavalry Storage EXTHD 500G|CAVA U2&ESATA...
Ethernet drive not spinning up.
You can always format it but if you have any data on it you will lost them
Dec 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Computer says my 500g HD is only 170g.
hi mate, i fixed it this way
right click on my computer > manage > disk management > (box bottom right you should see the rest of the drive space unalocated) click the unalocated drive box > create partition > the rest is history.
hope this helps mate.
Nov 18, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
External drive recognized as CD drive
You need to do a firmware flash. It worked for me. Here's the link to the fix.
http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=29
Mar 13, 2008 | Acomdata HybridDrive E5 Hard Drive
Mad Dog Multimedia MegaVault  USB 2.0 External Drive Case Logo
Top Mad Dog Multimedia Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
