From your description your referring to a corrupt file system, when windows boots it; loads sector zero and begins loading os files progressively, when a file fails to load like the registry hive or the core sytem kernel it will hang for hours, the system is in need of a system repair, step 1 try hitting the f8 key on system reboot, keep tapping till it loads into the chose boot options and slect the safe mode option. now asuming this is windows oporating system, you will be in safe mode, go to the start button click it and select run, type in the run box chkdsk /R now press enter it will take a while for the scan to compleate, when it's done reboot as normal and see if the system boots ok, if it fails here theirs other options but lets try that first.
