You have a defrost problem. You can defrost the unit down by removing the back panel and get a hair dryer and go back and forth over the defrost. Make sure that you don't get any of the coils too hot or you'll destroy your unit. But you'll need a meter to check which part or parts are bad. Do you have a meter? But you will either need a defrost timer, defrost heater or a defrost themostat. But you'll have to have a meter to OHM out the defrost heater. If your unit beeps then you'll need to replace the defrost timer and defrost themostat. If the heater checks bad then you'll need to replace only the defrost heater.
