Question about Dehumidifiers
I moved in a house with a Maytag Furnace that has attached dehumidifier. How do make it work. It is a little more than two years old and I have no manual.
Posted by drobinson021 on
Joe Hogan
  • 10,865 Answers
What you have there is a humidifier, not a dehumidifier.
Posted on Aug 20, 2009
Dehumidifier' problem
1. Very few companies manufacture their own dehumidifiers. 2. Due to cost concerns, the coils are made of steel (not something like stainless steel) and will rust / corode, causing refrigerant leakage, often times after only a couple of seasons. 3. Maytag is not the Maytag of 15 years ago. They cheapend their product to lower cost, looking for increased sales, and have been bought out by Whirlpool.
May 27, 2010 | Maytag M7DH45B2A Dehumidifier
Knocks out house curcuit breaker and stopes running. Use to work fine and did for at least two years now kicks out breaker after running for a while. Have moved it to different circuits and still does it....
You will need to put an amp meter on the compressor wires and monitor the reading till it trips the breaker. If the reading exceeds the name plate spec then chances are the compressor is going bad.If the spec is in watts, take your amp reading and multiply it by 120 volts this will give you the wattage of the compressor. For a second opinion take it to repairshop to see if it is worth repairing.
Good Luck!
Aug 15, 2009 | Maytag M7DH65B2A Dehumidifier
Lost manual I believe the model is DH90 U, it's about 9 years old
Here you go, good luck.
http://www.sylvane.com/images/productpages/DeLonghi/Dehumidifiers/DDH30-DDE40E-DDE50E-DDE65E.pdf
Jun 11, 2009 | DeLonghi DDE50E Dehumidifier
Dehumidifier running but not producing water
Sounds like your relay switch isn't connecting....
Apr 29, 2009 | Maytag M7DH65B2A Dehumidifier
Broken shut off lever
I saw a website that had parts.
http://www.appliancefactoryparts.com/dehumidifiers/helpcenter/breakdowns/maytag/maytag-m3dh30b2a-b.html
Looks like the float with the plastic tab was $7.99.
Jun 07, 2008 | Kenmore Dehumidifiers
Connecting a drain hose
Most units have a drain connection, either on the machine itself, or in the collection pail. These connections usually fit standard garden hoses.
Jul 05, 2007 | Maytag M3DH30B2A Dehumidifier
Humidifier that never shuts off.
I am having the same problem with mine and it has started freezing up for no reason. Did you get any answers
Nov 20, 2006 | GE AHG40LA Dehumidifier
Dehumidifiers Logo
54 people viewed this question
Top Dehumidifiers Experts
Marvin
Marvin
STEVE SPAM REMOVER
ray gallant
Are you a Dehumidifier Expert? Answer questions, earn points and help others
