Dryers Logo
Anonymous Posted on Aug 20, 2009
The dryer turns on but no heat is this the heating element or something else?
Anonymous
Level 3:
  • Kenmore Master 1,606 Answers
  • Posted on Aug 20, 2009
Anonymous
Kenmore Master
Level 3:
Answers
1606
Questions
Helped
569894
Points
5623
Either a thermal cut off (top of element housing ) or element . Test by removing the 2 wires to the little thermostat looking piece and attach them togather . If heats , replace the thermal cut off and the hi-limit t-stat . (comes in a kit ) . If still no heat , probably element . UNPLUG DRYER DURING THE WIRE CHANGING TEST . If you had included complete model number , could have given you part numbers .
Testimonial: "thank you that gives me somewhere to trouble shoot before I start replacing parts."
david mcclellan
Level 3:
  • Master 530 Answers
david mcclellan
Master
Level 3:
Answers
530
Questions
0
Helped
303166
Points
1839
Most likely it is the element. The only way to be sure is to visually inspect it.
1helpful
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
1helpful
2answers
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
2helpful
I have a may tag performa gas dryer. When I start it, it spins and heats but it spins very slow. I opened the top and checked the belt and it was tight and does not appear to be slipping. Is the motor...
  • There are a number of different problems which can occur with models of Maytag dryers resulting in them not heating and drying clothes properly. A variety of parts could have broken or been worn out over the course of the time you have been using your dryer or something could just malfunction, as appliances tend to do from time to time. Check warranty information before trying to repair the Maytag dryer yourself.
  • Bad Heating Element
  • Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
  • Broken Motor
  • Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
  • Bad Switch
  • When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch.
  • please stay how helpful it
    Dec 21, 2010 • Dryers
    Procedure to replace heating element on 84152 electric dryer
    This is a simple repair. Just follow these steps:
    1. UNPLUG dryer. Dangerous voltage is still present even with the dryer turned off.
    2. Remove the dryer vent exhaust hose and remove the back of the dryer.
    3. The heating circuits are located on the right hand side (as viewed from the rear). The heating element is located inside the heater box. Simply remove the mounting screws on the heater box and remove the two wires on the heating element terminals. NOTE: You can leave the two remaining components (Thermal Cut-Out and Hi limit Thermostat) connected on some models. If you need to remove them in order to remove the heating element make sure you label the wires.
    4. Locate the mounting screw(s) on the outside of the heater box that hold the heating element in place.
    5. With the mounting screw(s) removed the heating element will slide out of the heater box.
    6. Insert new heating element, making sure you avoid touching the coil and align the screw holes so you can reinsert the mounting screws.
    7. Re-install the heater box and any remaining components.
    Now...are you sure you have a bad heating element? Just because a dryer does not heat, does not necessarily mean the heating element is bad. The following link explains:
    http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
    The most common fail item that causes a dryer heating circuit failure is a blown TCO caused by poor dryer ventilation. Just something you may consider.
    If you have any questions, please let me know. I hope you find this information helpful.
    2helpful
    Electric dryer won't heat, maybe the heating element but before it stopped heating i cleaned the lint trap and something fell into it and i didn't notice and turned it on and could hear it hiting...
    Sounds like you broke the heating element. Go to a local shop and get one. You may have also burnt the timer so after element you may need a new timer as it tells it to put power to it.
    Heating element failed twice
    most dryers have a thermal fuse on the exhaust it may be open
    2answers
    Kenmore dryer 90 series model 66901692
    heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
    Top Kenmore Dryers Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
