Whirlpool Washer washer stops mid-cycle. It goes through the initial motions agitates and stops when it appears it should begin draining and rinsing (so it works for the first 10 or so minutes.) I have already replaced the timer with no success (with new timer the washer exhibits the same issue) and have checked the tubes for blockages (there were none I could see.) I removed the pump and inspected it as well.
If I set the timer to Heavy or Light, it will stop at the same spot, meaning that it will go through the entire heavy process as the timer proceeds towards the light wash cycle.
The Timer stops exactly in the middle between the Light and the Rinse and stop permanently
Washer will fill both small and large loads, and also will use hot or cold water as directed by the nobs on the control panel. Oddly enough it will agitate if I manually select the timer to rinse, but only for a short before it just abruptly stops.
This issue exists for all the different modes of wash (Regular, Permanent Press, Casual.)
Inspection of the wires and other tubes reveal no obvious sign of problem.
