Dometic Rooftop RV Air Conditioner Logo
Posted on Aug 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan Runs, AC Doesnt, Blinks 5 times
My Carrier AC in my RV will not cool. Fan runs, but when switched to cool it just blinks 5 times but will not cool. i know that the blinking light indicates something but not sure what. Please help!
thanks!
  • 1 more comment
  • b2breese Aug 20, 2009
    I dont have the model number with me as I am currently responding from work. Will check later. It is a ducted model in a 2002 Keystone Outback. The blinking is on the interior ceiling unit. There is a "AC ON" light and that is blinking 5 times but it does not operate. The only thing that works is the fan mode. I have not been able to locate the manual.
    Thanks for the help!
  • Mike Butler
    Mike Butler May 11, 2010
    Need to know model number & if it is ducted, non ducted etc. Does manual not say anything about the blinking? Is it blinking at ac unit, or remote control, or at thermostat?
  • Steve Rodden
    Steve Rodden May 10, 2022
    Did anyone find a solution? I'm having the same problem.
David Spradling
Level 3:
Top Expert:
  • Dometic Master 13,520 Answers
  • Posted on May 19, 2022
David Spradling
Dometic Master
Level 3:
Top Expert:
Answers
13520
Questions
0
Helped
927905
Points
28384
Check to see if compressor is running if not check start up capacitors
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Aug 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
4232
Points
30
Need to look around and should have an error code and give more detail of what the problem is. If you post that i can maybe help you more. I need to know......
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
MY RV Carrier AC has a blink 5 pause then blinks 5 again. Unpluged circuirt board and the fan and compressor will come on for a minute or so and the nothing no fan no compressor. The fan mode works
Well I'm not sure what model unit you have but I found a manual online for the AirV series that has a 5 flash code. States that to be a compressor drive issue. If yours is an AirV series, call a technician. No help in the manual.
I have a Carrier model 42KPC019303. It turns off while running. The LED blinks five times, stops, and then blinks 5 times again in cycles. After a few minutes, it turns back on again and off again after a...
hello
1- you check thermostat .
2-maybe temp your house is below 26c.
3-you check fan condenser and evaporator .
4-maybe cut off low pressure system.
Ac works for about 3 mins. then kicks out runs 5 mins. then cools for 3 mins.
circuit board. look at board on outside heater box most boards control both , check for flashing light and count blinks , read chart on blower about the flashes. new boards around 120.00
1helpful
My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
14helpful
4answers
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
1helpful
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
1helpful
Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
18helpful
6answers
My carrier A/C turns off by itself but the light blinks
Switch OFF the circuit breaker of ac, after 5 seconds. Switched ON the circuit breaker. If this will appear again try to check the wiring connection of ac.
2answers
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at [email protected]
Thank you very much.
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
