Question about Precor Exercise & Fitness
Precor treadmill C951i has code stuck key and will not run.
Posted by Frank and Pat Dixon on
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
Anonymous
SOURCE: c956 precor treadmill
Hi
not to sound funny but are you sure that you have this tread set in the units (mpg/kph) that you require. i have worked in loads of gyms and its a common problem that people think the belt is running to fast because its set in kph and that thinks its in miles eg 9mph = 14.5kph
you can check and change the units in the club setting menu.
hope this helps :)
Posted on Feb 12, 2010
WarrierX
SOURCE: I have precor 9.31
I had that problem and solved it by removing the red "STOP" cover. The cover pushes against a switch. If the switch moves too far down and rests against the cover, it will be stuck in a lock position causing the error message. To remove the red STOP cover, remove the few screws behind the console. When the front cover is off, turn it over and unscrew the two screws that hold the red stop cover. Then push the cover out through the FRONT. Do not attempt to lift it out by the end with the screw holes. It iwll not pull out that way. Test the machine before screwing the panels back agian. The message should no longer show STOP KEY. Test the visible white small switch that you uncovered by removing the red flap. The message should stop when you press the switch.
I kept the red STOP cover off of the switch and screwed the panels back into place. The machine now works fine!
Posted on Feb 10, 2011
mainedaniel
SOURCE: The belt on my Precor
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
Posted on Mar 06, 2011
Joshua
  • 95 Answers
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
Posted on Jan 13, 2012
My treadmill precor 954i showing stuck key. So what solution for this problem???
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is normally caused by a stuck key on your keypad. To resolve this issue, you must replace the keypad.
The following link may help, but you will need your serial number to find the correct item.
Repair Parts for Precor C954i Treadmills 120VAC 240VAC SPORTSMITH net
Nov 13, 2015 | Precor Exercise & Fitness
Stuck Key message won't go away-how to get rid of
please find an overview of safety keys for treadmills here as well as a direct link to purchase some :
http://www.treadmillsrepair.co.uk/2014/08/treadmill-safety-key.html
Aug 23, 2014 | Precor C956 Commercial Treadmill -...
Stuck key
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
Precor Repair Parts for 9 33 9 33i Treadmills Consumer SPORTSMITH net
Jul 15, 2014 | Precor 9.33 Treadmill
Precor gfx 9.33i displays "stuck key"
Corrective Action
Apr 20, 2014 | Precor Deck, Treadmill, OEM
Display reads key stuck
This link will help you step-by-step how to trouble shoot the stuck key issue. You'll want to start on page 18.
http://www.sportsmith.net/images/product_support%5Cprecor%5CService%20Manuals%5CCommercial%20Treadmill%5CC954i%20%28120%20VAC%29%28serial%20code%20AEXE,%20ADEY%29.pdf
Dec 02, 2013 | Precor C954i Commercial Treadmill
Precor 9.35 Error 5
please see the details and proceed according. God bless you
Dec 12, 2012 | Precor 9.35 Premium Series Treadmill
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Oct 10, 2012 | Precor 927 Treadmill
I have a precor 935 that is showing error 5 stuck key that wont clear. any ideas
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
Corrective Action
Precor Error Code 05
Feb 01, 2012 | Precor 935 Premium Series Treadmill
On my Precor 956 i the Stop Key prompt appears
There is a micro switch under the red "Stop" button. The switch is stuck and needs to be replaced.
Oct 24, 2010 | Precor 956i Experience Series Treadmill...
Key STuck Error
The key pad is not functioning properly thus this error is flashed you will need to replace key pad. Since I don't know where you are then the place to get the part is from precor directly the will ask Model & Serial #s
WORLD HEADQUARTERS20031 142nd Avenue NE
P.O. Box 7202
Woodinville, WA 98072-4002
T: 425-486-9292
T: 800-786-8404
www.precor.com
Jun 30, 2010 | Precor C954i Experience Treadmill
Exercise & Fitness Logo
157 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
