Question about Health & Beauty
SOURCE: I need a manual for
Bit of an off-the-wall solution, but call the number highlighted here, and see if they will send you a copy?
I can't find one online either - sorry about that.
Posted on Jun 24, 2008
SOURCE: Jazzy 1200 power wheelchair is electrically
When you say inoperable I am assuming you are not getting a flash code on the joystick. I would check the wiring from the charge meter on the rear? console - you will see a yellow slug in the harness that has a fuse in it - check all the wiring from the meter as this can cause a 'power loss' problem. Of course, check the battery connections as well.
Posted on Mar 27, 2009
SOURCE: wiring diagram needed
Hello, I went to this web site and paid for a complete wiring diagram www.wiring-diagram.com/complete/, it cost me, but now I have it, Good luck, hope this helps.
Posted on May 21, 2009
SOURCE: I have a Hoveround MVP 4 power wheelchair. I purc...
Hi. your problem could be a couple of faults. Have you checked that both tyres have the same pressure in them? Problem could also be a faulty motor or brake unit. When these motors have done a few years work they build up carbon and copper dust from the brushes and the commutator. the motors can be tested for this if you find a clever serviceman. The motors should also be tested to see if they are both drawing the same current ( amps ) when in use. In answer to your last question, the answer is probably no. Good luck. Neil.
Posted on May 28, 2010
SOURCE: Jazzy Quantum 600 power wheelchair - On the
THE WHEELCHAIR WILL ONLY TILT IT WILL NOT GO FORWARD OR BACKWARD USING THE JOYSTICK
Posted on Jul 14, 2011
Jan 01, 2016 | Health & Beauty
Sep 26, 2015 | Health & Beauty
May 21, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
Jan 31, 2012 | Electric Mobility 24 " Seat Merits Heavy...
Aug 23, 2011 | Invacare Pronto M51 Power Wheelchair
Sep 17, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Aug 02, 2010 | Jet 3 Ultra Power Chair
Jun 20, 2010 | Pride Mobility Products Quantum Jazzy 500...
Mar 01, 2009 | Jet 3 Ultra Power Chair
Feb 20, 2021 | The Health & Beauty
