MD-1700 keyboard lights up but won't do anything?
Based on your description, it sounds like your Blaupunkt 32-inch flatscreen TV may have a damaged screen. The ink-like appearance and brief flicker followed by a dark screen are indicative of a physical crack or damage to the screen.
It is possible that the TV was able to function normally after the fall, but over time the damage to the screen worsened and is now causing the issues you are experiencing. Unfortunately, this type of damage is typically not repairable and would require a replacement of the entire screen, which can be costly.
If the TV is still under warranty, you may be able to get it repaired or replaced through the manufacturer. Otherwise, you may need to consider purchasing a new TV if the cost of repairing the the screen is prohibitive.
Hi charles bergius, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
It's a TV not a computer so I moved you.
get the manual and see how to reset it.
Each TV made not the same way so the manual needs to cover this.
one way is plug power cord in , as you old the power button then old for 10seconds and release
