Question about Kenmore Refrigerators
Sears Kenmore 253.7041341B freezer works refrigirator is not cooling
Posted by Kevin Thompson on
ray gallant
    Top Expert:
  • Kenmore Master
  • 68,584 Answers
COULD BE AS SIMPLE A FIX AS CLEANING THE DIRT OFF THE EVAP SCREEN UNDER IT
Posted on Jul 04, 2019
Testimonial: "did that. its only 18 months old too."
  • ray gallant Jul 05, 2019
    TURN THE REF DIAL UP TO A HIGHER NUMBER IT IS POSSIBLE IT NEEDS A TECH TO TEST THE PROBLEM
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Posted on Nov 09, 2007
Anonymous
  • 700 Answers
SOURCE: whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Posted on Jan 01, 2009
Anonymous
  • 544 Answers
SOURCE: GE Model # GSS20IEPA WW Fridge warm...freezer is fine
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Posted on Mar 28, 2009
Anonymous
  • 3 Answers
SOURCE: Sears Kenmore Deep Freezer settings
i tilt my chest kenmore deep freezer to remove water when cleaning it by the time it was connected it didnt work
Posted on Jan 21, 2010
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Posted on Mar 29, 2010
Testimonial: "Good suggestion i will check tonight."
There is problem with our kenmore refrigirator the freezer is working but the refrigirator is not working. the refrigirator is not cold enogh it is going to 60 degree
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Refrigerators
FREEZER IS WORKING OK, BUT REFRIGIRATOR IS ABOUT 10 DEEGRES CENTIGRATES. Serial Number LA93506717
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 04, 2011 | Refrigerators
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 02, 2010 | GE GSH25JFT
Refrigirator side not cooling but freezer side is working, fan is working
if you open the freezer back wall you see that there is ice all over that prevent colld air go to the fridg.
use hair dryer to melt all the ice (turn unit off)
then you might need to replace the heat unit or the thermostat in the freezer to prevent it to build ice again.
Dec 28, 2009 | Kenmore Refrigerators
Freezer (top) is cool, but refrigirator at room temperature
Your first step is to make sure the condenser coils and the fan are clean and there is nothing blocking air flow around the outside of the fridge. A good vaccuming and brushing will do it wonders.
If this does not improve the operation. Tell the landlord that it is bad and if it is part of the supplied appliances, he should replace or repair it for you.
If he is not cooporative, do some online searches for methods to convince him to do his job or who to contact to ensure he doesn't cause you harm.
Sep 20, 2009 | Whirlpool ET4WSKXK Top Freezer...
Freezer is defrosting and refrigirator is not cooling
If the compressor and the fan work , probably the unit is laeking freon, but if the condenser fan doesn't work ,the compressor will go of on overload, also the problem could be with the compressor relay.
Sep 19, 2009 | Kenmore Refrigerators
Refrigirator is not cooling. Freezer is cooling
if you have a bottom freezer, you need to defrost the unit the cool air from the freeezer is what cools the top part, but the channels are iced up
unplug the unit and let it thaw out overnight
Sep 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
No cooling
is there frost building up on the back wall of the freezer?mike
Mar 16, 2009 | Kenmore Refrigerators
Refrigerators Logo
123 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
