HP DeskJet 932c InkJet Printer Logo
Posted on Aug 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The orange light is blinking and I have replaced the cartridges...Help
Anonymous
Level 3:
  • Master 855 Answers
  • Posted on Aug 19, 2009
Anonymous
Master
Level 3:
Answers
855
Questions
0
Helped
271312
Points
2699
If the printer is working properly it sounds like you may have to take cartridges out, reinstall and make sure you run the alignment. This should solve your problem.
3answers
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Originally the black ink would not print. replaced, primed, cleaned. nothing, the same problem, no black ink. Now I can't get the cartridge light to quite blinking. It is not steady orange, but a...
First off, if you touched the metal contacts on the printer or cartridge, you could damage or leave a film on the contact surface. Take it out of the printer, with a qtip dip in rubbing alcohol, squeeze out access, rub surfaces, air dry, and reinsert again. If still no ink, turn the print end up under the very hot water tap and run for 2 minutes. Dry and replace. It may do the trick.
9helpful
2answers
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
The orange ink cartridge light keeps blinking. We
the problem is that your cartridges are expired or bad, just replace the two cartridges with a new one
3helpful
The top orange light is blinking and it says its offline??? What do we do??
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
1helpful
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
BLINKING ORANGE LIGHT AND NO PRINTING
I just experienced this with my 920c. I cleaned the contacts in the cartridge holders with alcohol and the problem went away.
4helpful
Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
On/off button & restore button blink green & orange; printer doesn't work
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
2answers
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
k24674
Grand Canyon Tech
Grand Canyon Tech
