Tablets & eReaders Logo
Laura Doyle Posted on Jul 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Karcher wv2 window vac won't charge. Button light no longer comes on. It is plugged in correctly.
repairlass89
Level 2:
Habit-Forming:
New Friend:
  • Expert 176 Answers
  • Posted on Jul 29, 2022
repairlass89
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
176
Questions
0
Helped
43653
Points
261
Do u need charge battery may be a fuse in plug or change power supply
2answers
Why won't my Kocaso tablet hold a charge?
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on. Support Troubleshooting Guide
Why want my tablet come on?
Will no turn on after charging
Kocaso tablet won't hold a charge
Wont start up
My tablet has a charge problem
Tablet charges but won't boot up
Won't charge
Will not turn on
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
