Televison & Video Logo
Question about Alba Televison & Video
Where can i get code for a alba tv on my tesco remote i lost the code instructions its an albs tv dvd 24gy15t2
Posted by david felton on
5 Related Answers
Gigatech
Rafael Ortiz
  • 259 Answers
SOURCE: RCA remote instructions for Sony Cable TV
1. Turn on the device you wish to program. 2. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH.
3. Press and release the device button for the device you are programming (TV, VCR or DBS•CABLE). The INDICATOR LIGHT will blink once then remain lit. DVD codes are programmed under the VCR button. Note: For AUX, press DVD•AUXthen the device button you are assigning to DVD•AUX. 4. Press and release ON•OFF until your device turns off. Important: You may have to press ON•OFF up to 200 times. 5. When your device turns off, press the ENTER button, the INDICATOR LIGHT will go off
Posted on Apr 21, 2008
Anonymous
SOURCE: RCA universal remote modle #RCR311w need instructions and codes for LXI tv
http://remotefinder.rca.com/default.aspx?site=rca is the only place you have to go to. It works!
Posted on Dec 23, 2008
Anonymous
SOURCE: Gemini Easy 3 remote control that I lost the instructions -need code forS ony Trinitron TV -- Original Remote Model was KV-2644R
gemni3 quick 50 codes for samsung tv
Posted on Jan 29, 2009
Anonymous
SOURCE: NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
Posted on May 30, 2009
Anonymous
SOURCE: sansui tv remote code ALLFORONE Universal Remote URC2020B02
i have a one for all remote how do i program it to a sansui tv
Posted on Dec 19, 2009
1helpful
Urc 7130
If you do not find any set-up code by its code list, just try a code search method. Sometimes, you might succeed. Common codes to check with Alba brand TVs are, 1061 1206 10511210 1075 1130 1083 1032 1225 1147 1157 1190 1052 1035. If you wish to get more check the site linked here. http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://remotesearch.blogspot.com/
I have an Alba digital lcd/dvd combi 16" CFD1671A. We have lost the remote control so I have bought a replacement universal control. I cannot get it to recognise any code - do you have any ideas...
This tv is an unknown brand and produced by some geric electronics copannies.U will not find any codes for it an universal remote.Try website like Remotes.com might can buy an original tv remote.
Universal remote code for alba lcd22880hdf tv?
Hello
Universal remote codes for Alba TV with Chunghop RM-962 remote control are:
0705 / 0711 / 0730 / 0731 / 0738 & 0744.
OK.
Have alba 17" tv/dvd/ipod combo.have
try contacting the manufacturer or the retailer where you bought it. otherwise, buy a universal remote control like the logitech harmony, wich is programmable to the extreme
2helpful
Tryin to progam my sky remote to tv got a 32in alba new one the sky remote has flashed tiwce still no joy its has been working ok for 2 months got up today would not work
Firstly, try changing the batteries. If you've already changed then the remote has probably lost the TV code.
If you can post your exact Alba Model number, I will post the correct code and programming instructions for you.
It would also be useful if you can post you Sky remote version number - it's on a sticker in the battery compartment. I need to know if it's Rev 8, Rev 6, Rev 4 or just RC1600/00.
2answers
2 remote controls needed
Chances are that you won't need a new remote. Universal remotes often have a code-search feature in case the codes provided don't work. I suggest looking in the instructions (if you have them) for a "code search." If you don't have the instructions, you could google your universal remote manufacturer and model number and see if you can find an online manual. I hope this helps, and good luck! Der Strom
I need codes for a remote ,BD512
there are no coides published for ALBA TV ,try Pressing SET (&hold)and (1) key ,indicator will flash eg. 4 times for Digit 4 etc,repeat this step ,with (2)key for the 2nd digit and (3) key for 3rd digit,good luck
Top Alba Televison & Video Experts
Ernest
Ernest
ADMIN Eric
ADMIN Eric
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
