Question about Xerox Office Equipment & Supplies
Xerox u9-5 code on a 5028 copier
What is the problem, what is the cost of repairs and how do i clear this error code
Posted by aluwishous on
Everett Lin
    President:
  • Xerox Master
  • 990 Answers
Hello sir; There is a reset procedure require;
hold down 0 while you turn on the power, then enter 20 press start enter 3 press start. turn power off and on.
Posted on Aug 19, 2009
Anonymous
    Scholar:
  • 136 Answers
Yes but if the Problem continues and keeps coming back the you ave a problem in the fuser unit which is not that expensive of a repair. if your in the Connecticut area . Our company does service these copy machines. our company name is Copiers Plus Worldwide,LLC.
thank you
Posted on Dec 07, 2009
  • Anonymous Dec 07, 2009
    I have a copy Cartirdge for this unit. Look us up in the Connecticut area
    13R9 I ave a Brand new ill to sell it cheap
    Copiers Plus Worldwide,LLC is our company name
I'm having trouble code 80 for the machine processes the file and not print accuses engine failure''firmware''someone could help me please, I have changed the image processor board and...
hi there
Error Description: Engine Logic Board Failure, Code 80
Possible Solution:
1. Cycle power to the printer to clear the error.
2. Did this clear the error? If, yes problem resolved , if no, replace the engine control board , or,
The image processor board
eng log brd part # required, 160K85653 cost approximate $125
proc brd 650-4306-00 aproximate cost $160
hope this helps -- please send me 4 thumbs up
Jul 10, 2011 | Xerox Phaser 7750DN Laser Printer
For document centre c250 fuji xerox: error code 062-380 or error code 062-386
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
Aug 04, 2010 | Xerox CopyCentre C128 Black and White...
XEROX COPIER XC865 HAS AN H4 ERROR CODE HOW TO RESET AND WHAT DOES IT MEAN
H4Fuser temperature too low. Must be reset in diagnostics
Dec 18, 2009 | Xerox XC356 Copier
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
Xerox XC1875 U4 Error on Startup
Give this a try. it may clear you code. Use program 14
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
**To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics.
May 04, 2009 | Xerox Office Equipment & Supplies
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
Jun 30, 2008 | Xerox Office Equipment & Supplies
381 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
