Question about Refrigerators
The refrigeration unit in my Tuscany wine cellar is not maintaining the 57? temperature it kept before. Can you provide me with some suggestions or contacts?
Posted by George Manya on
jws1013
  • 1,708 Answers
You will need to contact a refrigeration repair service in your area.
Posted on Jul 04, 2019
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: VP500 Cooling unit issues
http://www.rosehillwinecellars.com/3rsV2/54_RHWC_plans/tuscany_plus_250_500.pdf
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
Posted on Oct 23, 2007
Anonymous
  • 19 Answers
SOURCE: Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Posted on Feb 21, 2009
Anonymous
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
Anonymous
  • 334 Answers
SOURCE: Temperature control does not work. Unit freezes
Either the thermostat itself is bad, or the relay is sticking. If you break the connection between the T-stat and the relay, and it keeps runnning, the problem is the relay.
If the compressor stops running when you break the connection or disconnect the T-stat, then the T-stat needs to be replaced.
Posted on Oct 12, 2009
Anonymous
  • 288 Answers
SOURCE: My kool space wine cellar is not holding temperature
has the cellar ever worked right in your home? These small refrigeration units basically move heat from a conditioned space to another space that is not objectionable such as your home where your central air system then moves the btu's. This being said, the cellar has a ventilation system that must pull in room air and push out the box air. these vents must be clean and clear of obstrucions to ensure proper performance by the equipment
Posted on Nov 27, 2009
My thermostat is reading 48 and I can't get it cool enough in my wine cellar to turn off the unit so that I can adjust the temperature up to 55. Is there a place that I can put some ice on to lower the...
IF THE CELLAR TEMPERATURE IS AS YOU SAY 48 DEGREES AND IF YOU ARE TURNING THE SCREW ADJUSTMENT ALL THE WAY TO THE WARMER SETTING COUNTER CLOCK WISE AND THE UNIT DOESNT SHUT OFF YOU HAVE A BAD THERMOSTAT AND NEED TO REPLACE IT
Aug 04, 2011 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
I have a Koolspace AA6 Tuscany free standing unit. Sn 05314-11. Power went out cooling unit will not restart. I get the thermostat to read and fan to turn for a while then goes into high temp alarm mode.
It seems like this cooling unit (AA6, also Grand Cru 800) just doesn't last as per numerous postings that I found when I was trying to find a replacement unit. Best advise seems to be get a higher output unit that will fit application.
May 14, 2010 | Vintage Keeper Koolspace Wine Cellar
Nov 26, 2009 | Vintage Keeper Koolspace Wine Cellar
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
I have a Carrier split unit model 38AN009100 that I am using to refrigerate my wine cellar.I know that this unit is not made for this purpose. Is it possible to convert it so I can control my cellar at...
well most unite will but out 54 degrees but as far room temp reaching that is highly unlikely. the unite would probably turn into a big hunk of ice and stop! this is more of Refrigeration unite which operate at lower temp. you can buy small ones fairly cheap. try EBay.
Jul 07, 2009 | Heating & Cooling
Oct 23, 2007 | Vintage Keeper VP500 Wine Cooler
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
