Question about GE Televison & Video
I need my 4 digit code for my original ge d52gw12 remote
5 Suggested Answers
Anonymous
  • 363 Answers
SOURCE: remote control code
You need to let us know the make and exact model number of the universal remote. All universal remotes do not use the same codes. We'll try to help you control your technics sa-gx100 upon your reply.
Posted on Sep 29, 2007
Anonymous
SOURCE: philips universal remote 4 digit codes
For combination tv/vcr the codes on the Phillips remote are 0039, 0739. I can only enter the channel I want to watch I can not use the up and down arrows for some reason.
sb2141
Posted on Feb 15, 2008
Anonymous
SOURCE: GE Universal Remote Code for Hannspree Tv
Try 0063
Posted on Aug 31, 2008
CiNi
  • 144 Answers
SOURCE: code for jvc tv with ge universal remote
Here are the GE Universal Remote 4 digit codes for a JVC TV.
0060... 0026... 0197... 0069... 0160...0247... 0923... 0012... 0065... 0067... 0141
Direct Code Entry
1. Press and hold the SETUP
button until the red
indicator stays on, then
release the SETUP button.
2. Press and release the
desired Mode button (TV,
VCR, etc.). The red
indicator blinks, then
stays lit.
3. Enter the 4 digit code from
the code tables. Note:
after a valid code entry,
the red indicator turns off.
For an invalid code, the
red indicator flashes.
4.With your device on,
press CHANNEL UP. If
the device responds, no
further programming is
required. Note: If some
buttons do not operate
your device, try one of the
other codes for your
brand.
Note, when all codes have
been searched the red
indicator flashes rapidly for 3 seconds.
Hope this helps!
Sincerely, CBR2009
Posted on Aug 01, 2009
Anonymous
SOURCE: I need the 4 digit remote code for a Sharp Aquos
Try 0093 mate.....
Rgds,
Nik..
Posted on Jul 24, 2010
Have GE 4 device universal remote 7252 12404 CL3 1214. Need remote codes for Sansui TV.
Sansui TV codes are 0310, 0394, and 20695. If your universal remote only works with 4 digits, you can only try the first 2 codes. If your remote uses 5 digit codes, add a 0 in front of the 4 digit codes to try them.
Additional codes that are less likely 1023, 1107, 1122, 1273, 1382, 1383, 1384.
Aug 16, 2016 | GE Televison & Video
I need a Toshiba DVD code using universal remote GE
There are two different ways to go about it one has people using 3 digit codes and the other using 4 digit codes. I will link to both of those here. Combo devices 4 digit Cable GE universal remote control codes Old 3 digit codes for DVD and VCR GE universal remote control codes
Feb 09, 2015 | GE Televison & Video
Need tv code for remote ge jc024 for a apex tv
I am getting following 4-digit codes for Apex TV for GE remote controllers.
APEX ..........0214 0216 0215 1132 0401
Sep 08, 2014 | GE Remote Original Jc024 Remote Control...
Roku
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy. 0029,0036,0035,0031. Check these codes first.
Mar 17, 2013 | GE JASRM24912 Remote Control
Need four digit code to unlock GE model 25GT240
Hello
To unlock GE TV, you must have its original remote control.
Most GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each procedings until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Jun 09, 2011 | Televison & Video
I have a GE universal r emote control. I need the codes to control a 2006 Toshiba TV.
Hello;
According to the site located at http://www.eliztech.com/remotes/ge-4digit-codes.php , GE Universal Remotes operate on 3 and 4-digit codes. Furthermore, the 3-digit codes are sub-categorized as "old" and "new". So depending on how you classify your tv and whether your remote uses 3 or 4-digit codes, the codes for a Toshiba TV are:
3-digit (old) 049, 071, 072, 089, 105, 109, 117, 118, 160, 162
3-digit (new) 012, 013, 049, 089, 095, 105, 109, 117, 118, 120, 141, 159, 170, 178, 181, 260, 358, 394, 902
4-digit 0159, 0178, 0109, 0120, 0181, 0105, 0049, 0095, 0170, 0260, 0358, 0394, 0924, 0012, 0095, 0117, 0141
Hope these are the right codes.
Mar 19, 2011 | GE RM24911 Remote Control
I need codes for GE universal remote 24993 for Orion TVs
Try these out: 035, 121, 135, 191 If it is a 4 digit coded unit: 0121, 0135, 0035 Hope this helps.
Mar 02, 2011 | GE 24993 Remote Control
GE D52GW12 turns off
I have the same problem, what the heck. it's over for it
Jun 09, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52 in. Rear Projection HDTV-Ready
Please report these problems to the consumer product safety commision. I beleieve this common problem with large sparks and flames warrants a recall.
https://www.cpsc.gov/cgibin/incident.aspx
Aug 06, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
