Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Freezer has defrosted itself fridge still seems to b workin but warnin light for freezer temp is on? Iv tried the fast freeze but it hasnt worked
Posted by janetpendris on
fixrguy
  • 415 Answers
Is this a manual type unit or just a chest type freezer if just a freezer as soon as it reaches a temp of 08 the alarm should stop
Posted on Aug 19, 2009
Hi Iv got a Hotpoint fridge freezer iced diamond rfa52 it keeps switching on and off it seems when the fridge gets warm it turns back on my freezer is not defrosting but the fridge is then freezing again...
Okay, have you adjusted your cold temp knob inside the fridge part? There are two switches one in the freezer and one in the fridge you will need to watch it day by day until the optimum temp setting has been achieved same goes for the freezer if it defrosts that is the exact point where your freezer is at best! It takes patience so be patient and your problem will be solved! Good luck and thanks again for using fixya.com
Oct 09, 2014 | Hotpoint Refrigerators
Crystal cold lpg fridge the fridge part works fine but the freezer only cools to the same temp as the fride compartment
The freezer should go down to about zero degrees. If your unit is constantly running it is because the internal temp has not activated the thermostat to turn off the compressor. Lower than normal refrigerant levels could account for this. Also to be checked out is the evaporator coil not being frozen over with a block of ice - the latter is caused by an inoperable self defroster - this causes the freezer to not cool properly and raise all internal temps.
If not a self defrosting unit, defrost the unit and restart unit. It will cool properly until the evaporator freezes up again. How fast it freezes up depends on how often the freezer door is opened and how much moist warm air enters the freezer compartment.
Nov 21, 2013 | Refrigerators
Freezer not staying frozen and ice maker not making ice
Sounds like your fridge guy is right. Just be sure coils are defrosted again when new heater is installed.
Sep 22, 2017 | Electrolux Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Bottom freezer has high temperature and is defrosting. temperature alert light is on. Tried fast freeze button and turning up the temp gages but nothing seems to be working.
as for high tempreture do u mean it is above the 0 degree normal that its supposed to be set to your freezer goes into a defrost cycel once every 6-8 hours.if your tempreture is rising on the other hand there are a couple things for you to check make sure the fan inside the freezer compartment is running.the following things you will need a meter for to measure the resistance while the power is off check the t-stat,heater to make sure there is continuity if you have continuity in both of these then you would need to check the defrost timer If you are unable to do these tests i strongly suggest you call a technician
Apr 28, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
Refrig does not turn itself off except at very low
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Refrigerators
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
365 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
