this is a V22 chassis circa 2003/2004
you could have an issue in 1 or multiple circuits. it is key if you can determine any error code. Error code is determined by blinking LEDs on front of unit after it shuts down. It will blink a certain number of times, pause then blink another certain number of times. It repeats this cycle 5 times.
12...no fault detected
21...X-Ray protect
22...short circuit protect
When you unplug the set it then when powered up waits for the DM unit to boot up----the green light blinks on the front for about 70 seconds and when it goes out the set can be turned on.
If this is the case I have a suggestion, let me know if I have described the situation correctly.
check the error blink code again as 56 is not a valid error code for the WD62525
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Did you push in the device and the menu buttons at the same time and get the error code... I have the same problem and I get a 1,2 code.... I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is [email protected]
Push device and Menu in on the front panel together and hold for 8 seconds and see if the led blinks a two digit code. As it may be the lamp or quite possibly the Power PWB capacitors if it blink a 3 4 code.
Mitsubishi's have an error code system (press both menu and input/device buttons on the front panel, the green light will flash a 2-digit code...(example one flash short pause two flashes=12 long pause then it will repeat four more times...error 12 is no problem found...the other codes are 21,22,23 and 24.........Good Luck.
