Question about Pioneer Car Audio & Video
Pioneer Car Stereo DEH-2290UB - How to adjust speakers through balance button
Posted by Paul Premkumar on
Robert Rankin
  • 378 Answers
5 Related Answers
Anonymous
SOURCE: WIRING FOR PIONEER DEH 16 CAR STEREO
you need to find the Pioneer website, or something similer... google the DEH 1600 diagram. really you just need something that tells what the different wires represent by color. then find a wiring diagram for the make and model of your ride that cooresponds to your stereo set up... then just match up the wires and there you go... personally i suggest haveing one of the boys at Best buy throw a harness... it costs like 15 bucks or something. plus you know it will be done right, and you can take it back if its not and have it fixed... bottom line they will be liable for any problems... hope this helps.
Posted on May 26, 2008
Anonymous
SOURCE: Lost Faceplate for Car Stereo Pioneer Premier DEH-P700BT
e-bay
Posted on Feb 02, 2009
Anonymous
  • 3 Answers
SOURCE: I installed a pioneer Deh p49001b car stereo in a
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
Posted on Aug 12, 2009
apollosarmy
  • 4 Answers
SOURCE: Pioneer DEH-1100MP stereo no working
Is it older then a year? warranty or call18004211404. If your fuse is good check these. check you harness for a GOOD ground, check for power with a meter reader. For some reason on these units if your constant 12v and ignition 12v are both not hooked up it wont even do a thing. make sure both are connected. no loose connects?
Posted on Aug 16, 2009
santange
  • 99 Answers
SOURCE: pioneer DEH-P3100UB car stereo keeps turning off and on again
broken wire, or dirty connection....oh check your ground wire for radio...
Posted on Jan 04, 2010
How do I reset my pioneer deh-x6500bt car stereo and produce sound from my rear speakers?
a 'reset' of the entire stereo should be able to be accomplished by disconnecting the battery for several minutes: alternately if you remove the faceplate there should be a reset button you would need a pen to press, however you should be able to find the EQ levels and set the balance and fade I think it is so the rear produces sound, if that is not the case, I would check wiring to make sure nothing is loose. I suppose it could only be a software/firmware problem with the stereo itself however, if you have had this happen before and it was fixed without tinkering with the wiring.
Jul 30, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
How do I set the volume on both speakers?
Go to the stereo fader and balance the volume in each speakers. You can see there L for left speaker R for right speaker and F for front speaker and then R for rear speaker. Put them all in zero to have equal sounds volume.
Apr 06, 2011 | Pioneer DEH-P2000 CD Player
How do I set the speakers sound right and left front and back
press audio button till you get to either balance or fader and use the seek up and down buttons to adjust them
Feb 23, 2010 | Pioneer DEH-1800 CD Player
Adjusting front and speakers
Push the menu/sel button, select bal/fad. Pioneers use the same adjustment for balance and fade. push side to side for balance, up and down for adjusting front to rear
Aug 18, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
How to ajust speaker front to back
Hello bill_cordova,
Start with the "AUDIO" button. Press it until FAD appears in the display. Press the up/down buttons to adjust front/rear balance. FAD:F15-FAD:R15 is displayed as the front/rear balance is moved from front to rear. FAD:0 is the center position with the balance equal between the front/rear speakers.
Hope this helps. If it does, please rate as "FixYa".
Apr 24, 2009 | Pioneer DEH-P4700MP CD Player
Pioneer car sttereo without manual. front speakers work but rear speakers silent
Press the audio button (A button in right hand upper corner) till you see FADE or BAL press the up down or left right arrows to adjust the fade and balance till all your speakers work.
If they still dont work, check the wiring at the speaker and the wiring behind the head unit to make sure their properly intact and properly grounded.
Jul 28, 2008 | Pioneer DEH-1600 CD Player
Speaker Balance
its the shift button. that lets you adjust your bass treble fade and other stuff.
Sep 03, 2007 | Pioneer DEH-245 CD Changer
Wire Color Code
what color is what on the pioneer deh-p4100
Jul 12, 2007 | Pioneer DEH-P4100
Car Audio & Video Logo
143 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
