Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
Ge profile arctica not cooling. Pulled it out from the wall, had technician clean dust out in grates behind freezer. Checked motherboard (no visible burnt transistors) and all electrical connections? Refrigerator and freezer began to work again, and then stopped cooling again 3 days later? It's humming like it normally does, but sounds like one of the fans is not running that you normally hear?
Posted by ari_lehner on
5 Related Answers
docjohn174
john gagnon
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
Anonymous
  • 40 Answers
SOURCE: Top Freezer Not Cooling...Fan Running...everything thawed :(
Check the thermostat in the refrigerator and make sure it's not accidently turned to the defrost mode
Posted on Jan 08, 2009
Anonymous
  • 14 Answers
SOURCE: Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Posted on Jul 07, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Posted on Jul 12, 2009
Anonymous
  • 103 Answers
SOURCE: power is on but no control indicators are visible
Unplug this refrig from the wall, let sit for one hour, then plug back in, if it starts then you may have a start device on compressor that is bad, more than likely it won't, normally the HRS means there is a "main board" problem. Main board is located on rear of refrig.
Posted on Oct 17, 2009
I opened my freezer (arctica) and heard a sizzling sound -- i could see coils behind the grates on the back wall of the freezer that were bright red (like an electric stove coil on high) -- the water was...
I hope you unplugged your unit or tripped the breaker. If they are bright red then you have an electrical short that should have tripped the breaker a long time before they turned red hot.
Jul 15, 2011 | GE Profile Arctica Stainless Steel Top...
Freezer will not freeze. Fan is always running
pull the ref out from the wall remove the back panel and see if the condenser coil is dirty if so unplug the ref clean the coil and place a fan behind the ref for 1 hour to cool the compressor then plug it back up give it 24hours to get back into cycle
Nov 18, 2010 | GE Profile Arctica Stainless Steel Top...
I have a GE Profile Arctica Fridge. The temperature in the Freezer has dropped to 34 degrees and the Fridge has dropped to 40. The fridge is running and is blowing air in the freezer, but not really...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile Arctica Stainless Steel Top...
Freezer not getting cold enough ge profile aritca side by side
i pulled the steel access panel on the backside at the bottom. there your coil is on the right side. i just vacuumed all the dust off of it; it was really bad. hope this helps
Jul 22, 2010 | GE Profile Arctica 25.4 Cubic Feet...
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Aug 05, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
Jul 07, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Jan 08, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
Aug 27, 2008 | GE Profile Arctica Stainless Steel Top...
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
1,262 people viewed this question
Top Refrigerators Experts
Ron Rak
Ron Rak
gbob59
