I cant find the light bulb in my Emerson MWG9111SL. How do I replace it?
The light bulb is usually in cavity behind the control board.to access that first remove the outer cover of the unit by removing all screw at the back.after removing the cover u will have access to yhe cavity behind the cntrl board and the light bulb.....good luck.
You will need to remove the cover over the top and sides. it is one piece. The two lower screws are a star bit that reqires the bit to have a hole in it. I could not find any, so I used pliars to remove them. When you get it open, you will see a blue and orange wire that attaches to the top. pull back the plastic and use a small knife or something to bend the tab that locks the connector in place. Below is a link to where I just located one for alot cheaper than some of the previous sites. BE SURE TO UNPLUG THE MIROWAVE BEFORE DOING ANYTHING!! AND DO NOT TOUCH ANYTHING ELSE!! There are some resistors (one gigantic one that could knock you on your "you know what". http://www.ereplacementparts.com/emerson-mwg9111sl-microwave-parts-c-126248_126259_169483.html
