Question about Zebra 203DPI Printer
My zm400 keeps reverting back to direct thermal
Originally i was getting the ribbon in errors, i realized that this was because it had gotten set to direct thermal, i need transfer thermal since I use ribbon. I go into the printer settings on the lcd screen, go to select transfer thermal, save it. the machine then will print one label out and give me the ribbon in error again.
Basically i need it to stay on thermal transfer but it keeps going back to direct thermal. i save the changes i make in the printer it just seems to forget them after one sticker.
suggestions?
Posted by dude_wtf? on
Anonymous
  • 21 Answers
Did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
Posted on Aug 20, 2009
Chinst3r
    New Friend:
I had the opposite issue, where I needed it to be Direct and it kept reverting to thermal Transfer. I went into the printer properties and changed everything to Direct, and saved all the settings. I eventually noticed that it worked when I did not have the Zebra Setup Tools installed. Go Figure.
Posted on Jun 24, 2013
Raza Hashmi
    New Friend:
  • 11 Answers
You have to change parameters in driver option kindly i you are using printer online then you have to change thermal transfer and media type non-continious web sensing.
Posted on Jun 25, 2014
I cant perform anything on my printer because when i turn it on it comes with a ribbon and paper out error.what should i do
please check if you fit the paper and ribbon at correct place (under the crome plate and between the printheard and white roller.
Aug 22, 2014 | Zebra ZM400 Thermal Label Printer -...
Black horizontal line on zm400
check the pressure of the printhead.increase the pressure of the printhead.
its a ribbon friction line.
Dec 28, 2013 | Zebra ZM400 Direct Thermal-Thermal...
Hello, I changed the ribbon. The ribbon and labels
can you adjust the printhead pressure?? if so then do that
Aug 22, 2017 | Zebra ZM400 Thermal Label Printer -...
Will not print onto the label. but can see it on the black ribbon reel.
Perhaps your darkness is set too low, or your labels are not coated to accept thermal transfer printing. Let me know if this helps!
Aug 28, 2011 | Zebra ZM400 Thermal Label Printer -...
I've got some problems with my zebra zm400 printer. It says error ribbin out
The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
May 05, 2011 | Zebra 203DPI Printer
I have a Z140XiIII that used to have a ribbon and thermal transfer stock. we changed the stock to not require a ribbon, so we removed the ribbon and set the menu to Thermal direct. labels print OK but the...
If the printer is flashing "Ribbon in" then it sounds like the printer setting to Thermal Direct is being changed back to Thermal Trans. Verify this after sending a format. This is very common because the printer is bring over-ridden by the software and/or printer driver when you send a format.
Look for a setting in the software / driver for direct thermal and make the change there.
Hope that helps.
Apr 21, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
Error condition ribbon out in ZM400
In the printer setting-
Change the Print Method from - "Tharmal Transfer to Direct Thermal" and save it permanently
Aug 10, 2009 | Zebra 105SL Thermal Label Printer
ZM400 printer
Try going through the LCD menu and if it say "Direct Thermal" change it to "Thermal Transfer", Direct Thermal made means, no ribbon required, but it sounds like you do have ribbon in the printer, if so, try my recommendation. If it asks for a password, it's '1234'.
Oct 14, 2008 | Zebra 203DPI Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Zebra 203DPI Printer Logo
6,148 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
