Question about Minolta Office Equipment & Supplies
HOW DO I SOLVE THIS ERROR CODE COF E8 IN MINOLTA EP 2030
Norman J Weimar Jr
  • Minolta Master
  • 6,960 Answers
Replace the drum and developer if it can be found and run the correct service procedure
Posted on Feb 17, 2020
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: Error code COF 32
sry, cant find this code
Posted on Jun 19, 2008
Anonymous
SOURCE: meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
Posted on Nov 03, 2008
Anonymous
  • 25 Answers
SOURCE: Minolta copier EP 2030 error code C 04
No, in stand-by the exposure lamp should not switch on. What comes on in regular intervals is the heating lamp inside the fusing roler which can be seen from the exit side of the copies. The exposure lamp is under the glass and only comes on and print button is pressed and copy process begins.
GOOD LUCK.
Posted on Nov 04, 2008
Anonymous
  • 143 Answers
This unit has a history of the High Voltage unit going bad. NOT good news, and NOT a cheap fix.
Posted on Jun 26, 2009
Testimonial: "Thanks for your advice I am success"
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: ep 2030 error code c06
Exposue lamp, does the lamp come on under the glass at all. Open close the front door, if that code comes back your exposure lamp is gone. Thats the bright ligh that comes on while making copies.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 19, 2009
Minolta EP 2030 error code C05 how to reset
open the front door with power on in the upper left you should see a small panel remove the cover, press the small switch wait for ready to copy, if the code comes back do not reset the FUSER is bad it can start a FIRE ruining a perfectly good day!!!!!
Minolta cs pro 2030 C00 CODE SHOW PLZ HELP
Missing two numbers on the end of the 00 is it 0070 or 0000?, 0000 is main motor drive 0070 is toner bottle issue.
Error cof 10 en minolta 2030
Open close front door to reset. If it comes back must remove the original glass the large glass. Then remove the lens cover there is a sensor the monitors the exposure lamp the bright lite it might be bad or the board it feeds is bad
We have Minolta Ep2010, It is showing error cof e8, how to solve this
There are small sensor under the big glass that look at the size of the document to figure what size it is, well one is bad they look like little bug eye looking up at the glass. replace one or both, try below web site for rough cost if available
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
4helpful
2answers
Ep 2030 error code c06
5helpful
6answers
Meaning of code C04 ( EP 2030)
Top Minolta Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Mehandi Husain ...
George Mclaughlin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
