I have entered the ip address in a browser the it tells me to enter user name and password as expected.i type admin leaving the password blank.the router's configuration page does not open.please help.
Someone may have changed the password in the past.
There is no way to tell what it has been changed to.
You can try obvious ones like "admin" and "password"
But if you can't guess it you may have to do a factory reset.
This will reset the password and everything else.
It may be case sensitive username. Try Admin and admin.
with blank password. or Password, password.
There is not much to do, if the Default ID had been changed the router control panel will not start.
Try first the default values, these depending on BIOS revision are:
PW: Blank
or
PW: Blank
Other D-Link router may also have
ID Admin
PW admin (case sensitive).
If those details do not work, uou will need to reset the router to factory settings, using the pin hole reset switch at the back, and then you will need to enter all parameters given by your provider again.
Try password: admin
User: admin
pass: administrator
Is a common one I run into. Especially if it has been on a radio ISP. Otherwise, reset to factory and re-configure.
Step 2:
Go to the Address bar and enter your router's IP Address, then press [Enter].
NOTE: The default IP Address of a WMB54G is 192.168.1.210.
NOTE: If the IP address of the WMB54G has been changed, type the WMB54G's new IP address in the Address bar instead.
The WMB54G's IP address can be changed by:
Running the WMB54G's setup CD.
Changing it on the WMB54G's web-based setup page.
If you forgot the WMB54G's IP address you can:
NOTE: This procedure will reset the WMB54G to factory defaults. Any settings on the Music Bridge will be erased. The Music Bridge's IP address will be 192.168.1.210and the password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank, type "admin" in the Password field, then click OK.
NOTE: If the password of the WMB54G has been changed, type the Music Bridge's new password in the Password field instead.
Step 1:
Open your web browser.
Step 2:
Enter your router's IP address type 192.168.1.1(no www) on the address bar and press the Enter key.
NOTE: The router's default IP address is http://192.168.1.1.
Step 3:
The Enter Network Password window will then appear. Type your router's User name and Password. Click OK afterwards.
NOTE: Your router's default password is "admin" and leave username blank.
On the router's web-based setup page, you'll be able to see your wireless tab and under the Wireless we have wireless security sub tab.
• you will now see you wpa-shared key/passphrase/wep key(that is what your looking for)
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory
defaults. Any settings on the router will be erased. The router's IP
address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
