Question about Electrical Supplies
Looking for a replacement fuel switch for scorpion sc950 petrol generator
Posted by Peter Phillips on
Generator Guru Parts
    Master:
  • Electrical S... Master
  • 269 Answers
Hi!
We sell this fuel petcock: https://www.generatorguru.com/fuel-valve-petcock-78317950/
If you need any other parts: https://www.generatorguru.com/sc960/
We also have a whole Help Center and Engineers dedicated to helping people fix their Portable Generators. In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Looking for a replacement fuel switch for scorpion - image-2fwsrbehqcya13uxwt41l5dc-5-0_6.jpg
Posted on Aug 19, 2019
Ron Rak
    Habit-Forming:
  • 138 Answers
3 Related Answers
worldvet
Glenn Rogers
  • 859 Answers
SOURCE: Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Posted on Oct 28, 2008
Colin
  • 1584 Answers
SOURCE: looking for a fuel line diagram
If you disconnected them (2) simply experiment as it will only start and run if correct way round!!!
Posted on Feb 24, 2010
denis
  • 144 Answers
SOURCE: Hi, A friend has given me
Hi Lance, you must have a dipstick or wherever you checked for the level of oil. That is where you add the oil. I have found this to be where the oil goes in the smaller generators. I hope I am right and this is helpful a bit to you. Any question welcome. All the best and good luck.
Posted on Feb 23, 2011
How do I tune a carby for a Mitsubishi PM 1500 L Scorpion generator
pull the carby and clean it out
the indication is that there is a blockage in the main jet or not enough fuel flow into the carby
check filter in the tank above the fuel tap, check the fuel tap for flow
there is no tune up points as it is a basic carby to run the engine at set rpms
Jul 05, 2016 | Electrical Supplies
Regards,
Worldvet
Oct 28, 2008 | Ryobi 15" Electric Factory Reconditioned...
Clarke 2200kw generator will not start Have changed spark plug checked flters put in fresh petrol
are you getting spark , is the on switch on , some people forget to do this
Jan 19, 2015 | Electrical Supplies
Suzuki alto fuel cut off switch location
why not post symptoms, and not guess at parts that may or may-not
exist.?
the fuel cut off switch is the ignition key, and works all the time.
The Maruti Alto is the Indian-built version of the fifth generation Alto
796 cc (0.8 L) F8D I3 (petrol)
998 cc (1.0 L) K10B I3 (petrol)
1,061 cc (1.1 L) F10D I4 (petrol)
or
Seventh generation (HA25) Alto from Japan.
796 cc (0.8 L) I3 (petrol)
what engine, the fuel systems vary by engine, and country sold to.
neither sated.
Mar 21, 2014 | Suzuki Alto Cars & Trucks
.comWhat is fuel to oil
I believe it should be 25:1 which is (say) 40ml oil to 1L of petrol. I have seen this ratio on a sticker on my grass scorpion.
Sep 13, 2011 | Ryobi Garden
Hi, A friend has given me a second hand, but still in good nick, Scorpion SC950 generator. It appears to have an oil leak and I am cant find where to top the oil up. Could you please advise me as to...
Feb 23, 2011 | Garden
Hi Please can you confirm what fuel the Ryobi rg6700k generator takes?
Hi. I've been looking online and there's no information about this model. However this is how to tell which fuel it uses. If it has a spark-plug it burns petrol. Diesel engines don't have spark-plugs they use glow plugs which are different. Spark-plugs have a spark gap which the spark jumps across while glow plugs do not.
If it has a separate place for putting oil, and a dipstick for checking the oil level, then the fuel is petrol only. If it doesn't have a place for oil then the fuel is petrol mixed with 2 stroke oil. I hope this answers your question.
Jan 19, 2011 | Garden
My generator ran last night but shut down before power was restored. I looked at the generator this morning and seen there was a UF alarm. This generator is less than a year old and there was hardly any...
THAT DEPENDS ON YOU'R WARRENTY.HOW MANY TIMES CAN YOU BRING IT BACK AND IF YOU USE IT THE 2 TIME IT MIGHT GET WORST AND YOU'LL BE WITH OUT A GENERATOR FOR A LONG TIME MAYBE,I WOULD ASK THE PERSON IF I CONTINUE HAVING THE SAME PROBLEM CAN I BRING IT BACK AND GET A REPLACMENT..REMINDER GO TO YOUTUBE AND TYPE [ what can I do with ALTINATOR you might like? ]
Feb 03, 2018 | Kohler 18RESL 18 kW Emergency Power...
Manual for Ryobi Grass Scorpion Line Trimmer
my ryobi scorpion only has twofuel lines but two on primer can you help
Mar 13, 2009 | Ryobi Garden
Electrical Supplies Logo
122 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
