2006 ion saturn....ignition switch stays in the run position and will not move back to acc or off position...
what is this????
Does your key stays in the ignition position? or can you turn it back to acc or lock? it might be a stuck ignition switch mechanism inside or a shorted circuit that latches the ignition...have it checked or you can try to open it the switch yourself..but with caution if this is your first time. Pls give me a feedback. thanks!
One of the pins inside ignition may have gotten stuck. You can try tapping lightly with ballpeen hammer around igniton to see if pins loosen up. Otherwise, you can try to wiggle shifter to see if keys turn. With shifter in park, press up past park and you should be good
Mite b a safety problem try shifting to park or neutril.....MAKE SURE U HAVE PARKING BRAKE ON
