Cell Phones Logo
Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Other person can't here me speak
My Blackberry Curve 8300 has problems. When I dial a number, it sounds as if it is in speaker phone but it continues to call. During the call, I can hear the other person speak but they can't hear anything from me.
Anonymous
Level 2:
Scholar:
  • Expert 87 Answers
  • Posted on Aug 18, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
87
Questions
0
Helped
33763
Points
302
It definitely is not the speaker but the Microphone; we got to have tested no smart way out.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
How to turn speaker phone on on a blackberry 8330 ?
newer blackberries turn speaker phone on by when your in a call pressing the blackberry button next to the control pad to bring up options and then scrolling to find speaker phone on this may work
4answers
Unlock blackberry 830 curve
To unlock the Blackberry Curve 8300 ,Buy the unlock code for Blackberry 8300 from the site Mobile-unlocker.com and unlock it.You can enter the unlock code following the instructions below:
Warning : Do not enter any wrong unlock codes on your Blackberry 8300 Curve mobile phones. If you enter over a certain amount of wrong unlock codes on your Blackberry 8300 Curve mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Blackberry 8300 Curve without any Sim card.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Hold the ALT Key while typing in MEPE or MEPD or MEPPE or MEPPD ( not case sensitive ) ( you will not see text appear on screen while typing ).
7 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
8 - Your Blackberry 8300 Curve will now be unlocked.
My phone has a weird dial tone. it breaks up i cant hear the person on the other side.. i try putting my phone on speaker but i cant hear anything.. when i use my headphones only one works.. what can it...
had same problem.
1) connect earphones and try a test call. If it sounds ok with h/phones then
2) record yourself / some music and see if it plays back ok. If it does then it's not the speaker or microphone. I found that this test miraculously cured the prob.
If it doesn't then take it back to supplier.
I have a BBRY 8300 Curve and I cannot hear anything in my phone's speaker
then you should take the phone and have the speaker replaced or the pcb main board looked at.
Blackberry Curve Buttons
How long have you had the phone? Use the appropriate means through your carrier to have the phone either warranty replaced or serviced. Depending on your carrier their customer service number should be on your bill. If you need further assistance let me know. Thank you,
Lee
1helpful
Blackberry curve 8130 phone category
This will typically happen when you need to clean your trackwheel.
I've done this, but it's a little scary - it looks pretty easy to break your trackwheel..
http://www.blackberryforums.com/general-8300-series-discussion-curve/108122-how-clean-your-8300-blackberry-trackball-pic-guide.html
No sound from Bluetooth
sound as in you can not hear the person speaker or the phone ringing on your end....if these are the problems maybe the BT headset is faulty
My house phone always gets a busy signal when calling blackberry
you will need to take this up with your carrier it does sound strange...maybe you could try entering the area code before dialing the cell number.
2helpful
3answers
Cannot hear the dial tone or the person on the other end
Your speaker could be going out.  When making a call press the $ button to activate the speaker.  See if that function works.
Adjust the volume with the volume control on the right  side of the as needed.
2answers
Try using the voice dialing feature. I had the same problem until I used the voice dialing. It worked fine after that.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
