Question about KitchenAid Kitchen Ranges
Need to reset KITCHENAID dishwasher model KUDP02FRSS2 control lock lite on tried several sequences ..nothing seems to work
Hard wired..turned power off for 8 minutes..tapped key pads 3 times in diff sequence..cancel pad..time delay pad...phone person my wife talked to was very pleasant..but unable to solve problem..can you help me? Thanks Roger. [email protected]
Posted by Roger Champagne on
5 Related Answers
AlPal
SOURCE: Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Mar 24, 2008
Anonymous
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Posted on Jan 16, 2009
TpUg
  • 25 Answers
SOURCE: KItchen Aid Dishwasher KUDI01FL Stopped Running and Will not Start
try the reset button sequence i posted in the other question..
Posted on Jan 24, 2009
erica graber
  • 530 Answers
SOURCE: whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Posted on Apr 14, 2009
Anonymous
SOURCE: Kenmore 665 15899
To reset and run diagnosis on the model 15899100 Kenmore Dishwasher you need to press the following buttons on your front panel. Hi Temp, Air Dry, Hi temp, Air Dry. The sears service technician just left my house and used these codes to reset and run diag on my washer.
Hope this helps
Posted on May 28, 2009
I have a Kitchenaid kuds25shwh1 which doesn't start because the childlock was on. I followed all the suggestions offered and lastly turning the power off to reset. After turning the power back on a...
Getting it out of child lock can be difficult but make sure you watch the light on the front panel it will go right back to lock if your not careful.I had to try several times at first I thought it would need a doctor.. but with patience it should work and unlock with the 4 second hold.. power down does not reset unless you wait 30 minutes or longer.. hope this helps
Oct 08, 2013 | KitchenAid 24 in. KUDI01FL - Multiple...
Cancel Light Flashing on Kitchen Aid Dishwasher
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
No control panel lites. Washer started then stopped as if power shut off.
Hello John - Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn on the unit. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Jul 03, 2013 | Frigidaire Dishwashers
Is there a reset button on the dishwasher? if so, where?
Not sure what type of reset you are after. Is the dishwasher not responding to any panel switches.
Is the keypad locked, i.e., is the control lock light on? Then press Energy Saver Dry button for 4-5 secs.
Are some lights flashing and dishwasher will not start? Have you tried to turn mains power off and back on?
If you think the controller needs a reset, you could try this sequence of keys within 7-8 secs.
hi temp scrub/ energy saver dry/hi tempscrub/ energy saver dry/ hi temp scrub/ energy saver dry.
If the reset sequence has worked correctly, then all lights should light up. Press Cancel to exit from reset mode. I am assuming you have a users manual. If not then download from here.
Please rate the solution if it helps your problem otherwise post a comment
Feb 18, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Child lock blinking on a Kitchenaid ultima diswasher.
Try holding the E.S. button down for 30 seconds. Does not work, you need an Electronic control assembly which can be ordered online from Repair clinic .com for $146 for your model plus shipping. This is apparently a common problem with Kitchenaid dishwashers. Just repaired one the other day. Tried everything, but as soon as the new Electronic control assembly was installed, everything was Okay. This is an easy repair for anyone who is handy at all. Please shut off power to the dishwasher by switching the breaker off or removing the fuse.
Feb 04, 2010 | KitchenAid KUDR25 Dishwasher
My KitchenAid dishwasher will not run. Start light is blinking
Make sure the controls are not locked. Some units have the ability to lock the controls so that kids cannot turn on the dishwaher. You can also try unpugging the power to the unit from under the sink for about 10 minutes and then plug it back in. This may reset the control board if it has a fault and stopped from error code.
Sep 26, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Jan 13, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean Light Flashes
Oct 07, 2006 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Ranges Logo
264 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
wp4eld1
Level 1 Expert
gbob59
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
