Question about Rock & Ice Climbing
Missing instructions how can i get instuctions for the 8 in 1 climbing frame that shows different positions etc>?
Posted by dthery on
Anonymous
  • 121 Answers
Posted on Oct 21, 2009
Logik recorder - error message - cannot schedule recording, there is already a timer at the same time on this channel. turned the box off at the wall & retuned. Any suggestions? Thank you. x
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
Jun 25, 2016 | Televison & Video
How do I program this remote start . I just got this for a replacment one and It never came with the instuctions Please help me?
Instructions
    • 1 Climb into your Jeep Grand Cherokee with your keyless remote(s) in hand and your manual ignition key. Do not close the driver's door.
    • 2 Hit the "Lock" switch on your driver's side door and insert the key into the ignition.
    • 3 Turn the key to the "Run" position and aim the keyless remote at the steering wheel. Press and hold the "Lock" button for five seconds.
    • 4 Wait for the locks to respond by cycling then program each successive remote (up to four total) by holding the lock until the locks respond. Each remote must be programmed within 20 seconds of the last.
    • 5 Turn the key in the ignition back to the "Off" position then quickly back to the "Run" position within 20 seconds of programming your last remote.
    • 6 Turn the car off and remove the key from the ignition to complete the programming sequence.
hope this helps
Jan 19, 2015 | 2000 Jeep Grand Cherokee Limited
Pictures not showing.
make sure the cards' slide button is in the unlock position..then check to see which size cards the frame can work with..mb sizes like 2/4/6/8/12 etc..
Jan 11, 2014 | Audiovox DPF700 Digital Picture Frame
I just purchased the Danco 52406 Shower W/Frame Add-On and wanted to install an different shower head...the Danco fixture is 3/8 and most heads are 1/2". I took the instructions with me to the local...
I would try to find a 3/8 to 1/2 NPT adaptor on Amazon.
If Danco has a website, it's likely that the instructions for your model are available in the support section of the website.
Nov 29, 2017 | Home
2002 Ford Mustang GT I used OBD-II to get the trouble codes, I got P0174,P0301,P302,P316 Freeze Frame Information: 1. DTC for which Freeze Frame was Stored - P0174 2. Fuel System 1 Status - Closed...
Because you got a misfire on cylinder #1 PO301
A misfire on cylinder #2 PO302
Misfires first 1000 rev PO316
O2 Codes PO 174
Etc,Etc
The LTT, is the result of not learning (yet-thus long term)
what isn't working correctly---Your Engine
Replace bad Coil--which ever is missing
Do not go by the codes,alone ,TEST
Dec 10, 2010 | 2002 Ford Mustang
I have a Woods 24 hours indoor lighting timer. I have followed the instructions provided with the timer, but lamp won't come on. Can someone please provide EXACT step by step instructions. Thank you
If you have a different model number than the 59377, please re-post with exact model number
If you programmed conflicting on-off schedules, the timer will not perform correctly
Make a schedule of times before starting, and that will keep everything organized, just like a recipe
How to program Woods 59377
Timer has rechargeable battery.
Plug timer into wall to charge battery to see LCD display.
All the Woods manuals
Download Woods 59377 manual
Up to 8 ON/OFF programs per day >> program 1 program 2 ... program 8
Choice of individual days, or blocks of days
Image shows buttons:
Set time of day:
Hold down CLOCK button until settings are made
Use DAY button to choose current day MO - TU etc
HOUR button to set current hour
MIN button to set current minute
Release Clock button and time is set
Program preview
> Have your schedule ready to avoid conflicts in programming
Manual says:
>For each ON time, you set DAY HOUR and MIN
>For each OFF time, you set DAY HOUR MIN
> So Program1 has ON and OFF settings that require DAY HOUR and MINUTE
> Program2, 3 , 4 etc also have ON and OFF settings that require DAY HOUR and MINUTE
>Manual shows blocks of days to choose from > for example TH FR SA is one block; MO WE FR is another block ,,, there are 9 possible blocks of days to choose from ... including individual days.
> Each program requires you to select days for ON time, and then when setting OFF time for that program, make sure you have correct day or block of days.
Looking at the display while programming is critical for programming timer correctly
Look for the number 1 or 2 or 3 etc located on left of display > each program has a number
program 1 is #1, program 2 is #2 etc >>> look for the small number on display
Look for the word ON that indicates you are setting ON time for program 1 or program 2
Look for word OFF that indicates you are setting OFF time for program 1 or program 2
Program timer
Press PROG once and look at screen ... you will see '1' and 'ON' in tiny letters
You are ready to set ON time for program 1
Press DAY to choose block of day for program 1
Press HOUR to choose ON hour for program 1
Press MIN to choose ON minute for program 1
Press PROG button once to validate ON time for program 1
Before pressing any more buttons, look at the screen >>> screen shows '1' and 'OFF' in tiny letters
So you are ready to set OFF times for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, you probably want OFF on same block of days
Press Hour to choose OFF hour for program 1
Press MIN to choose OFF minute for program 1
Press PROG to validate OFF time
Before pressing any button, look at screen and '2' and 'ON' show on screen
You are ready to set ON time for program 2
Press PROG button to advance to program 3 through program 8
Press ON/Off button to exit programming, and timer is ready
Other features
Daylight savings time: Press HOUR & MIN buttons simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Look for S in display to see if timer set for S summertime
Press reset to clear all programming
Up-vote if this information helped you. Thanks for the feedback
Oct 14, 2010 | Woods Industries 59377 Indoor Digital...
Casio Wave Ceptor 3353. Digital time is correct. Hands are about 15 minutes fast ahead . Cannot correct.
I have the casio 3353. When I read hte manual to do different things, it always startes the instruction by saying "in timekeeping mode". In the instuction booklet at page 8 it shows a picture of the watch face in timekeeping mode and in the picture the face shows the day and date. My face is showing the digital time here. How do I show the day and date,or the timekeeping mode?
Sep 09, 2010 | Casio DW9051B-1V Wrist Watch
Waste ink absorber full message showing on Cannon Pixma MP760. How to fix?
Follow this instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
Don't forget to replace the ink absorber.
Oct 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hotpoint wmm39 contol panel
The instruction book below has a picture of the control panel on page 17,from the off position turning clockwise the control dial is lettered position 1 = A, 2 = B etc http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/HBWMA48.pdf
Jun 11, 2009 | Hotpoint WMM39 Front Load Washer
Rock & Ice Climbing Logo
1,311 people viewed this question
Top Rock & Ice Climbing Experts
john h
Ned Halaweh
Ned Halaweh
ray gallant
Are you a Rock and Ice Climbing Expert? Answer questions, earn points and help others
