Question about Stanley Professional Backpack Poly 4-Gallon Sprayer #61804
The spray unit bent and broke...
Where can I get a replacement without buying the whole unit?
Posted by stanboydinc on
Anonymous
    President:
  • 512 Answers
Lowes or Home depot sells replacement sprayers. Hose to tip all included.
Posted on Aug 18, 2009
Aux input not working
Unfortunately the whole head unit needs to be replaced if the actual port is broken,but before you spend all of that money buying and installing a new head unit,try to replace the cable that you are using.if it still does it after the new cable then try to get some electric contact cleaner spray from the auto parts store CRC makes a good cleaner spray.Spray it into the aux port on the head unit and see if that works.If that does not work then replace the whole head unit
Apr 01, 2014 | 2010 Chevrolet Cobalt
Numark needle broke
Generally yes. Just type the cartridge number into Google and it should find the right stylus - not needle!!!
Dec 28, 2012 | Numark ttUSB Turntable
Can i fix my 2003 mitsubishis bent valve or do I have to replace the whole engine?
It depends on how much damage the valves did or didn't do to the pistons when they hit and bent. At the very least you're looking at a cylinder head rebuild job. But if the valves hit the pistons hard, you're looking at a new engine.
Oct 23, 2017 | 2007 Mitsubishi Galant SE Sedan
I have a Dynex Wireless Optical Mouse, which I love. I accidently bent the part that goes into a port on my laptop and now it won't work. Is there a way to purchase the part I broke?
What you broke is the bluetooth receiver that is paired with your mouse. You can't replace it on its own, they're a pair. You will have to buy the whole kit again.
Aug 22, 2010 | Dynex Computers & Internet
I broke the glass outside on the door of my Zanussi oven ZOB 646 QX model. The price of this glass together with the panal costs about 1/2 of the oven price. Can I replace this glass without buying the...
In my experience of repairing ovens, it is usually possible to replace glass without going to the expense of replacing whole panel.
Check with the manufacture.
Hop this helps.
Dec 05, 2009 | Zanussi ZHQ575 Electric Double Oven
Left front sway bar has lost the lower bolt. Replace bolt & rubber or the whole thing?
You can buy a kit with everything you need from any auto parts store. If you mean replace the sway bar its self no you do not, unless its broke or bent.
Apr 15, 2009 | 2000 Ford Ranger SuperCab
Rock broke amber turn signal lens
Junk yard and they may only sell the Whole Unit Only.
I believe the Unit is a Sealed unit. I would advise the Entire Unit Be Replaced as Its sealed and Moisture will have you Buying bulbs by the Case.
Dec 30, 2008 | 1998 Dodge Durango
Stanley Professional Backpack Poly 4-Gallon Sprayer #61804 Logo
603 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
