Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
I have a sony kdf-46e2000, there is a pinkish stripe on the top and bottom of the screen, what is causing that?
Posted by john horita on
Remmy Moore
    President:
  • 1,734 Answers
Looks to me as an serious (but not uncommon) PSP board problem with Sony plasmas. Contact a Sony service center.
What problems have people had with quality control on these displays? Are they covered under warranty?
  1. Certain displays emitted an extremely loud buzz. This was covered by warranty repair.
  2. Certain displays had a problem with the Y/C delay on their S-video input. This was also correctable.
  3. One person reported red vertical lines on his display. Was this covered by warranty? Was it an input problem or a pixel problem?
  4. Afew bad pixels here and there are not covered under warranty. Largeclusters are generally covered. It's up to Sonys discretion. On the plus side, however, bad pixels are becoming increasingly rare. Mostpeople are reporting no bad pixels at all!
CALIBRATINGWhat needs to be calibrated on a plasma?
You needto calibrate most of the same things that need to be calibrated onother displays. About the only things that don't need to be done areconvergence and geometry. You can usually tinker with picture size andposition, but there's no need to deal with keystone or pincushionadjustments, etc.What is white level? What is black level? How are they adjusted?
Theadjustment for white level is usually labeled "Picture" (as onPanasonics) or "Contrast". "Brightness", on the other hand, refers tothe black level. Yes, this is apallingly counter intuitive. This FAQuses the terms "white level" and "black level", since they betterdescribe what you're actually adjusting, and they're the terms used byAvia and Video Essentials.
How do I adjust hue and saturation?
In another mysterious choice of terms, hue is controlled by the "Tint" setting,and saturation is controlled by the "Color" setting. This FAQ uses theterms "hue" and "saturation", since they're the terms used by Avia andVideo Essentials.
How do I set the white level on a plasma?
Youset the white level by adjusting the "Picture" setting. You will needto use a different test pattern than you would for a CRT. For both plasma displays and LCD displays, you should use the 10 IRE grayscalestep pattern. There are two criteria you want to match on your plasma.
First,you need to make sure the white level is low enough that your displayisn't thresholding (or clamping) bright levels. You should set thewhite level low enough that you can see each of the 10 IRE stepsdistinctly. The Sony seem not to exhibit clamping (in my limitedexperience), even at factory defaults, so this criterion may not beterribly useful.
Second, for the health of your display (e.g.to avoid burn-in), you should turn down the white level. Just becauseyour display can display blindingly bright pictures doesn't mean that it should. Plasma displays should be set between 21 fl and 25 fl light output; the Sony comeout of the factory at about 30 fl. On one ISF-calibrated Sony, 23fl was roughly equivalent to a Picture setting of -20 (in the usermenu, not the service menu). To set this precisely you'll need to bringin a calibration specialist, but you can do a lot of good by justdialing down the white level a lot. After seeing the display at 30 fl,23 fl will see very dim. But after a while, you'll find that 23 fl isplenty bright.
How do I set the black level on a plasma?
Youset the black level by adjusting the "Brightness" setting. You can usethe same test pattern you would use for any other display.
How do I calibrate grayscale (calibrate the color temperature)?
Unfortunately,this is one you can't do yourself. You need special equipment tomeasure the color. In fact, most ISF technicians lack the equipmentspecific to plasma calibration (a $15K gadget known as aspectroradiometer). But even the standard color measurement equipment(which calibrationists do have) will do a great job.
Thatsaid, one person who had his Sony display calibrated by an ISF specialist said that the Cinema / Warm setting was reasonably close to6500K out of the box. Using that setting is probably the best you'll doon your own.
If you're really determined to screw up yourdisplay, the RGB drive and cutoff settings in the service menu are used to adjust the color temperature.
How do I adjust the color decoder?
There are several issues here. Generally speaking, the Panasonic decoder seems topush blue a bit. The R-Y Axis Angle and B-Y Axis Gain in the servicemenu are used to correct this behavior.
There used to be aproblem on some Panasonics with the Y/C delay on the S-video input. Seethe Quality Control section for more information.
How do I adjust the gamma?
On the industrial model, there is a set of Advanced picture settings. Go to the Picture menu, turn Advanced on, and then hit the down-arrow. In the subsequentmenu you can adjust quite a few parameters, including select from a fewgamma settings.
This advanced menu appears to be missing from the consumer model.
How do I calibrate my consumer model given these missing menus?
Thereis apparently a way to activate these menus. Perhaps you can find acalibrationist or Panasonic technician would can turn them on longenough to do the calibration.
What's the overall calibration procedure?
In general, the order Avia sets out is the correct one. A more complete list is:
  1. White level (picture)
  2. Black level (brightness)
  3. Repeat (1) and (2) until you have a good balance.
  4. Grayscale (requires special hardware and mucking about in the service menu)
  5. Sharpness
  6. Hue and Saturation (tint and color)
  7. Color decoder (requires use of the service menu)
  8. Repeat (6) and (7) for red and green until you have a good balance.
SERVICE MENUHow do I access the service menu?
In a word, don't. See the service menu warningabove. If you're bound and determined to make use of the service menu,buy the service manual. It contains more than enough information foryou to ruin your display and/or kill yourself.
Posted on Aug 18, 2009
I have a KDF 46E2000.About a half hr ago i was playing xbox and noticed the top of my screen turn red from one side to the other, 1/2 in down. The very bottom of my screen is tinted blue but very...
The Optical Block is causing the problem. It has been a common problem and Sony may still have a recall on it. You can check it a 1800-222-sony. If it is not still covered, I would expect to spend 800.00 to 900.00 for the assembly plus 250.00 labor for a professional to replace it.
I hope this helps,
Skyassoc
Dec 08, 2010 | Sony Grand WEGA KF60DX100 60" Rear...
Sony KDF 3LCD Screen has a horizontal orange tint stripe at top
This problem is caused by a defect in the optical block. It causes about 1 - 1.5" tint usually green, orange, or yellow at the top of the screen. The part is very expensive, retails around $600-800 usually. You cannot fix it without replacing the optical block. They did have an extended warranties for this particular issue because of a class action lawsuit on certain models. Call Sony to see if your model is one of the ones they extended the warranties.
Oct 05, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-46E2000 LCD Projection TV
4 flashes is a bad fan, 3 flashes is lamp door switch
Jun 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blue stripes
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 10.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs
http://servicemanuals.vstore.ca/
Jan 05, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-46E2000 hd picture problems
MY Sony (same model) has OUTstanding picture resolution and quality., I never have blockiness on any of the sports channels. I would say, give Comcast a call and complain about their signal.. they have a tech come over for free diagnostics on your wiring..
Aug 13, 2007 | Sony KDF46E2000 46" Projection HDTV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
885 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
