Question about Radio Communications
My Nakamichi NEP - TW2 plus ear buds with one piece malfunctioning with red light blinking when placed in the charge compartment
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Can not turn ear piece on
According to the manual, you should only have to hold the power on button ( it is where the tiny phone handset symbol is ) for 2 seconds. Holding it for 5 seconds should turn the phone off. To Pair the headset to the phone requires this button to be held for 5 seconds also.
Posted on Sep 27, 2008
Anonymous
SOURCE: Ear hook and ear bud replacements for Motorola H375
Here a site for replacements.
MOTOROLA H500 REPLACEMENT EAR HOOK $4.50http://www.worldwidecelldeals.com/store/
Posted on Apr 02, 2009
Anonymous
SOURCE: Sennheisser cx300 ear buds ..one channel has lost volume.
I have been having the same problem for the past week, I have just fixed it, reading your post gave me the idea to clean them and it actually worked
What i did was to "heat them up" with a hair dryer so that any wax from my ear that had gotten inside would "melt", then I cleaned them with alcohol and a q-tip and I made sure I let a bit of alcohol to get inside the ear bud, then I dryed it with the hair dryer again very carefully and tested to see the results and WHALA works just fine
Posted on Jul 15, 2009
Anonymous
SOURCE: Only One Ear Bud Works
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Posted on Sep 19, 2009
Anonymous
  • 4 Answers
SOURCE: when battery is placed in charger, red light
You can jump start the battery by taking a piece of speaker wire2.gif (any wire) and contacting it to a 9-volt battery for 30-60 seconds. Make sure to contact the positive to positive and negative to negative, or you may short the battery. After jump starting it the battery should charge as normal.
Posted on Nov 02, 2009
Going on standbymode and power green light blinking TA4 nakamachi
I'm not familiar with this product, and there the best I offer is that you consult the user guide (which you probably already have)
http://www.ps2netdrivers.net/manual/nakamichi.ta-4/#manual
or (buy) a service manual (which it seems includes a troubleshooting guide) from any of a number places, two are given below:
http://www.manualszone.com/en/nakamichi-service-manuals/62888-NAKAMICHI-TA4-service-manual.html
and
http://www.nakamichi.owner-manuals.com/TA4-service-manual-NAKAMICHI.html
All three manuals/guides are available from
http://www.hifiengine.com/manual_library/nakamichi/ta-4.shtml
There other websites where you an download the service manual (I don't know if the are the 'official' service manual, or different ones that have been written by different people).
If you are really stuck contact Nakamichi through www.nakamichi.com or (what appears to be a more friendly site) http://www.nakamichi.co.uk/support
24.August.2014
Aug 24, 2014 | Audio Players & Recorders
The light wont stay on
Hi please try to do this and let me know. Remove the battery and give a look inside the battery compartment with spot light. Make sure that place are clean and there no damaged mark. Specially look the Battery connector pins. That should in proper place , not bend, not even sulfur layer there. Use ear buds and drop of alcohol for cleaning. After checking if every thing Ok then some how the power supply not able to connect the circuit board. Its happens when the connectivity cable disconnected or damaged, circuit board short or the power transformer stop working. For all this internal fault part confirmation you need to visit electronic repair center.
but before visit for repairing make sure the battery which one you use that's is fully charged with working condition. Thank you
Aug 09, 2012 | Samsung NV3 Digital Camera
Can't pair my VBT2050 with motorola Droid
BT2050 must be off.
Push power button and round top button on BT2050 ear piece at same time until white light stays on. Both must be held down together.
Once white light is continuosly on (not blinking) then put droid in "Scan for device " mode.
Pairing should then take place
Apr 05, 2010 | Jabra Bluetooth Headset with Adjustable...
Jabra red light of death
seeing the red light tells you that the jabra isn't fried or shorted and that there is life but there is a problem, the red light isn't blue when it should be. so have you read the directions your ear piece came with when you first bought it?... hold the on button until you see the blue light stays on.(blue light will flash fast then slow then come to a complete stop and stay on) once blue light stays on that should mean you can now find the ear piece on your cell phone to link up. if problem still isn't fixed then you might as well buy a new one.
Aug 04, 2009 | Jabra BT350 Bluetooth Headset Headset
Sharp 19" LCD blinking red light
Your tv needs servicing, it has developed some kind of circuit malfunction. You can send it too me for fast repairs and return. Or find a shop in your area.
e-mail me...
Feb 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Ear piece does not work. Station top light does not come on
The 500A base station is definitely compatible with the 510 earpiece. If the earpiece is turned off or unpaired the base station's red power light will be flashing. If the earpiece is already off, try turning it on by holding down the little black button on top. The base station will automatically try to find the earpiece and the blue light on top of the base will come on. If the earpiece is already on (slow flashing blue light on the mic boom) turn it off and back on again and wait for the base to find it.
Nov 10, 2008 | Plantronics - Bluetooth Headset Plus Base...
JUST HOLD DOWN THE MIDDLE OF THE EAR PIECE FOR EIGHT SECONDS
Jul 02, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Bluetooth ear piece
blinking red and green means the headset is in pairing mode and ready to be connected to your phone. This means it is either the first time you have paired the headset or you have depressed the volume +/- buttons simultaneously for more than 5 seconds. If your phone cannot find the headset, it may be a compatibility issue. Try pairing the headset with a friends phone, possibly a sony ericsson. Good luck.
Jul 15, 2007 | Sony Ericsson Akono HBH-608 Wireless...
Radio Communications Logo
277 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
