Question about Car Audio & Video
The car stereo has a red light that flashes and none of the buttons don't work
Posted by Elsie Stump on
5 Related Answers
Anonymous
SOURCE: Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Posted on Dec 21, 2007
mjap
Mark Payas
  • 107 Answers
SOURCE: stupid stereo
check the fuse. maybe its blown. sonys are sometimes packed with to much fuses for different part.
Posted on Jan 23, 2008
Anonymous
  • 24 Answers
SOURCE: I HAVE A KENWOOD KDC 122 CD CAR STEREO.
For the manual for this unit head to this page
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf]
However im pretty sure you actually use the volume or tune/seek to change the numbers then when changed to what you woudl liek again simply hit the main button you used to get into the clock setting originally,
Hope this helps
Cheers
Steve
Posted on Apr 03, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: screen is flashing and buttons dont work.
Check the video cable first.
Try connecting to a different computer.
If the cable is not causing the problem, then you have a faulty LCD controller board or a defective input signal board (the one where you hook up VGA/DVI cable). The LCD panel ribbon cable must also be tested or replaced.
PSU, Inverter and LCD panel are not faulty for sure.
Posted on May 28, 2009
Anonymous
SOURCE: Red light above display flashes but no functions working
hi Dave
I'm not the most technical person in the world but I think I've fixed mine which had the same problem this afternoon, which is how I came to find your message!
Right.. here's what I did. It would appear that you have some kinda mechanism jam (even if there's no disc in it), so... please excuse my non-techie terminology throughout.
By the way, I probably don't need to tell you this but unplug the unit from the mains first or you might light up if you touch something!
Working with the unit facing you (control side), remove the two small screws at the back (on the metal flange) and two medium screws from the right hand and left hand sides of the main casing, then slide it off from front to back so that you can see inside the recorder. If you look in and down at the CD tray transport mechanism you should see a white plastic 'cog' wheel on the left hand side of the unit near the bottom 'floor' of the machine. Carefully rotate this wheel with a finger CLOCKWISE (pushing the wheel from front to back), slowly and gently - don't force it - and you should see the CD tray mechanism and gubbins start to move; keep rotating until the tray comes right out, or as far as you think it goes. Then, plug the unit back in, and switch on - the tray SHOULD then be taken back into the machine, the red light will flash, and the display should come on. As I say, mine has, so try it and I hope it works for you!
All the best (we'll beat these damn machines yet!)
Kev
Posted on Jul 25, 2009
Why did this turn off by itself?
You may have a problem in the audio output chips in the unit, first check the speaker wires on the back for shorts, a common problem, if okay you will need a technician to take it to the next step.
Sep 05, 2012 | Audio Players & Recorders
How to reset check oil light
You mean the change oil light, right ??
If it has a red button on the fuse box, you turn the key on and push the button, the change oil light should flash, then you push the red button until the light goes off.
If you don't have the red button, you turn the key on, push the gas pedal to the floor three or four times, and the light should go off.
The method for your model should be in the back of your owners manual.
Aug 19, 2012 | 2002 Pontiac Grand Am
Epson powerlite 83+. It comes on, then the 'heat' light flashes
Go to http://files.support.epson.com/pdf/pl83pl/pl83pl00ug.pdf#page=80&view=FitV&pagemode=none page 80, "What to do when the lights flash" . If that doesn't do it or it's not clear, please get back to me.
Jun 26, 2009 | Epson PowerLite 83c+ Projector
Car Stereo Stopped working
go to the panasonic website and get you manual and read it and it should get you system right again
its free
Apr 06, 2009 | Panasonic CQ-RDP472N CD Player
Code for a tv remote
if u have a universal remote and none of the codes seem to work after trying all the codes and non still don t work follow these steps
1. make sure the power on the TV is turned on
2 press and hold code button until it flash twice
3 then press the TV mode button until the light flashes the press
4 power button until TV powers off
Feb 13, 2009 | Daewoo DTQ-20U4SC 20" TV
Celica stereo
are stereos known to be good. try buying wiring kit for use in your application.
Oct 27, 2008 | 1992 Toyota Celica
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Car Audio & Video Logo
106 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
