When I turn on the TV, The Guide-Plus feature pops up and I can't make it go away other than pressing the clear button. I don't want the Guide-Plus feature popping up at all.
Found this on page 55 of user manual. Hope it helps.
Problem: Every time I turn on the TV, the Guide is on the screen Solution: The GUIDE Plus+ system automatically appears on the screen when you use the TV button on the remote to turn on the TV. You can turn off this feature by pressing GUIDE on your remote control and then select the Menu bar. Press the right arrow button to select Setup. Choose Review options and select OFF.
its really pretty simple once you know what you are doing..press the guide button and read and follow instructions...it guides you through it...just go slow...you cant break it...just start over if you press wrong button...it provides all the info you need...try it again...
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
can you let me know if you got help for this? the gude plus menu is blank and keeps popping up in the middle of a show for no reason. then the picture goes out behind it. the sound works ok though.
Bring up TV Main Menu and select option 7 (TV Guide Plus Menu) Select option 1 (TV Guide Plus Setup) Find the MENU, GO BACK and Input button on your remote Press the MENU Button then immediately: Press the GO BACK button then immediately: Press the INPUT button.
Note: It is important to press the Menu, Go Back and Input buttons quickly (within a second of each other)
Question? Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on. Answer: The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A: Select the GUIDE Plus+™ Menu from the Main menu. Select Setup. Select Options. Select Off.
Option B: Select the GUIDE Plus+™ Menu from the Main menu. Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu. Select Off.
Option C: Press GUIDE on your remote control. Select the Menu bar. Press the right arrow button to select Setup. Choose Review Options. Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
