Question about Pioneer Car Audio & Video
Where to get a dual volume pod for a pioneer kx440 amplifier.. Thanks Trevor.
Posted by Trevor Hinrichsen on
1 Related Answer
Anonymous
SOURCE: two amplifier installation
not 100% sure but i think it is because your tryin to pull 2 much power from system try unbridgeing them
Posted on Feb 20, 2008
I would like to add my i-pod to the receiver so i could listen to the music what kind off cable would i need
An i-pod provides a standard headphone level output. The AVR-1803 has nine RCA stereo inputs that will accept the signal from the i-pod. You need a 3.5mm stereo TRS plug on one end and two RCA plugs on the other end to connect your i-pod to your amplifier. Note: Be careful to select a 3.5 mm plug that has a slim enough plastic moulding to fit into the i-pod headphone output. On your amplifier you simply select the analogue input that you have chosen to use. Be careful of levels when you are setting up. Set the volume of your i-pod to about 50% and set the input sensitivity to zero, press play on your i-pod and gradually increase the gain on your amplifier input. Hope this helps, Don.
Dec 08, 2013 | Denon AVR-1803 Receiver
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
I wired my dvc sub woofers to 4 ohms and bridged my pioneer gm-5400 amp and it cuts off when i turn the volume up.
1. Check if your power cable is of adequate Gauge 2. Try turning the volume down from the amplifier gain level 3. You could even check to see if your battery is on it's way out and just cant feed the amplifier with the power it needs. (very rare case) do the car lights dim when the volume is not really that loud? 4. There could be an error on the way the subs are connected, double check that you have absolutely configured them to run @ 4OHM. could be checked with a multimeter before connecting to the amplifier. 5. Another rare case is sometimes the fuse block expands when it heats up on loud volumes and can have contact issues so try tightening the socket that the fuse goes into. 6. It could also be a problem with one of the sub woofer or even the amplifier. more details might help me better understand the problem, but i hope this helps. dreamsystems
Feb 06, 2011 | Pioneer GM5400T 2-Channel Bridgeable...
Is there a lead you can buy so i can connect my ipod to an amplifier
Yes just connect the one below to the headphone socket of the I-Pod.
d7e400c.jpg3.5 Jack to two RCA jacks
May 10, 2010 | Pioneer A109 2-Channel Amplifier
Which terminals to use
if your amplifier is 2 ohm mono stable - you can wire them in parallel.
Put a piece of wire from one + terminal to the other + terminal on the subwoofer.
Then do the same to the -.
Now pick one pair of teminals from the subwoofer and wire it to the amplifier. (one set of subwoofer terminals will have 2 wires each).
If you reply with your amplifier make/model, I can tell you the best usage.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 30, 2009 | Pioneer TS-W307D4 Car Subwoofer
My pioneer 600w amplifier cuts at high volume...
this means that the enternal preamp is starting to fail eventualy it will make no sound at all if you would like you can use a 4 channel amplifier if you would like to keep this deck
Feb 05, 2009 | Pioneer GM-6300F Car Audio Amplifier
Pioneer deh-2000r cd tuner
The volume + switch may be stuck. Does the Vol+ switch click like the other switches or does it feel like the switch has collapsed?
Sep 18, 2008 | Car Audio & Video
My car stereo shuts off when i adjust the volume of my amplified subwoofer
your power suplly is either not good meaning the power cable is too small or you don not have enough ground. try adding a bigger cable for ground and power (dc).
Aug 12, 2008 | Pioneer MONO CAR AMP 1000W X 1 Car Audio...
Pioneer amplifier 1980's
bias can be out in shape of volume written bias-or it can be in printed circuit board as potentiometer labeled by bias word.
Nov 08, 2007 | Audio Players & Recorders
Car Audio & Video Logo
105 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
