Question about GE Refrigerators
GE Profile Artica icemaker does not make ice. model # PSC235GNA. We still get cold water .
Posted by shirway on
Anonymous
  • 10 Answers
Use a thermometer make sure freezer is normal operating temp if freezer is cold enough and water is filling ice maker you may have bad ice maker very simple system make sure your getting water 1st thing to check is for water if you have water and freezer is cold youll have ice
Posted on Aug 18, 2009
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE profile Artica, MDL# psc23mgnabb, ice maker won't make ice, plus refrigerator side is freezing the contents
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE Profile PFS22 33" Artica French Door...
I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
Cut and paste this Factory Service manual for your refrigerator.
The troubleshooting guide will help locate the bad part.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
The electricity went off yesterday while we were gone (not sure how long) and the freezer is no longer staying cold. The ice maker hasn't made any ice and it has melted on top of the other food. We have a...
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Icemaker stopped working even though it is in the "ON" position and the water still work - Help?
Think you would be better to turn the water off to fridge for a few moments and pull it away from the wall unplug power and remove ice maker. If after replugging the power and slowly opening the water supply you still see leaking from fill tube you will need to replace the water control valve. It's the valve that your water line attaches to on rear and near floor of your refrigerator. I will need a longer model number to come up with the part numbers, Sea Breeze
Sep 16, 2009 | GE Profile PFS22 33" Artica French Door...
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker doesn't make enough ice
Try turning the thermostat all the way down if it works you can back it down.
Nov 21, 2008 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
266 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
