Televison & Video Logo
Posted on Aug 18, 2009
Bush bdvd 8380 any ideas? thanks
Bush bdvd 8380 any ideas to unlock from region 2 to 1 or multi? thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
430
Points
I have a bush dvd8380 player when i put it on charging green light blinks nd it does not come on so how will i fix it
2answers
What is the unlock code/region hack for a Bush 12" portable DVD player? The model is CDVD12SWM.
Give this a run
Make Your DVD Player Region Free in Seconds
  1. Power on.
  2. Open tray.
  3. Push the info on remote once (with supplied remote). You will see numbers.
  4. Press 9 for multi-region. Keep trying until you see the number 9 appear in upper left corner.
  5. Power off.
  6. Power on.
tip
Bush DVD-2023 Region Free Fix Would you like to unlock your Bush...
Would you like to unlock your Bush DVD-2023 to Region Free?
Follow these steps to unlock your Bush DVD-2023:
  1. Press the Open button on your remote control
  2. Using your remote control, press 2, 8, 1, then 2
  3. Press the Close button on your remote control
Your Bush DVD-2023 is now Region Free.
I hope that helps.
on Apr 25, 2010 • Televison & Video
Is there a Unlock code for bush btvd91216w
This is everything that I have:
Try this general bush unlock:
Press Open tray
Press 2, 8, 1, 2 and Enter to get to the manufacturers settings
Select the required region, by pressing Enter on 9 for multi region
Press Close tray
If that didn't work, try this:
Try this one:
1. Press the Open button on your remote control to open the drive tray
2. Press the 9 button on your remote control
3. Press the 7 button on your remote control
4. Press the 3 button on your remote control
5. Press the 5 button on your remote control
6. Using the on screen menu, highlight the region option
7. Press the Right button on your remote control
8. Using your remote control, select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
9. Press the Enter button on your remote control
10. Press the Open button on your remote control to close the drive tray
Then there is the following and good luck:
Bush 1000
  1. Open the tray
  2. Insert a disc with desired region code, but do not close the disc tray
  3. Press 0, 1, 2, 3, Play
Bush 1005 / 2004A / DVDAV7
  1. Press the OPEN/CLOSE on the remote
  2. Press 3, 3, 0, 8, 8
  3. Press the button for the desired region or 0 for multi-region
  4. Press OPEN/CLOSE
  5. The on-screen display will now indicate the currently selected region
Bush 2000
  1. Open the disc tray
  2. Insert RC-1 DVD, don't close the disc tray
  3. Press 0, 1, 2, 3
  4. Press PLAY
    To activate RC 2:
  2. Insert RC-2 DVD, don't close the disc tray
  3. Press RETURN and PLAY
Bush 2002 / 2004
  1. Press OPEN
  2. Press 7, ENTER, 7
    A menu should appear (codefree=13)
    Method 2:
  1. Press OPEN
  2. Press 2, 0, 0, 1
Bush 2005 / 2008 / 2009
  1. Turn on the player
  2. Press OPEN/CLOSE
  3. Press ZOOM
  4. Press A/B
  5. Press Up, Left, Down, Right
    A note should be displayed.
  6. Turn it off
  7. Turn it on
Bush 2023 / 2024 / 2523
  1. Press OPEN
  2. Press 2, 8, 1, 2, Enter
  3. Set the country code to 13 and press Close
Bush 2028
    already region free
Bush 2039
  1. Press OPEN
  2. Press PROG
  3. Press ENTER three times
  4. Use UP/DOWN to select region
  5. Press STOP several times to set the region
Bush 2047
  1. Press OPEN, SETUP
  2. Go to "Preferences"
  3. Enter 2, 8, 1, 2
  4. Use UP/DOWN keys to select the region
  5. Press SETUP, OPEN
Bush DVD-102
  1. Press OPEN/CLOSE
  2. Press 2, 0, 0, 1
  3. Press ENTER
  4. Select RC (codefree=13). You can disable MacroVision, too.
  5. Press OPEN/CLOSE
Bush DVD-142TV
  1. Press DVD function on your TV set
  2. Press DVD Setup on the remote
  3. Press 1, 3, 6, 9
  4. Press Left three times
  5. Press RIGHT once
  6. Select VERSION
  7. Change the region code
Bush DVD-143TV
  1. Press DVD/TV, DVD
  2. Open the tray
  3. Press SETUP, Right, Left, Down, Up, Display
  4. Enter 0 (or 1-6 for other RC)
  5. Press Enter
    VCD/SVCD playback
  1. Press SETUP on remote
  2. Press Next, Prev, Next, Prev
    Ver should appear in the top right
  3. Change 3001 to 3000
  4. Change 5001 to 5000
Bush DVDAV11K
  1. Open the tray (be sure to be in stop mode)
  2. Press SETUP, Next, Prev, Next, Prev
  3. Select 255 for region free (use LEFT/RIGHT)
  4. Press SETUP
Bush DVDR3000
  1. The disc tray has to be empty
  2. Press TV/DVDR
  3. Press RETURN, DISPLAY
  4. Enter 8, 8, 8, 0
Bush DVHS1
  1. Press the DVD button on the remote
  2. Press OPEN
  3. Press 0, 5, 2, 0
  4. Press UP, DOWN, LEFT, RIGHT
  5. Change the region (0 = multi-region)
Bush DVRHS02
  1. Push SETUP button on the remote
  2. Select SYSTEM INFO on the menu
  3. Enter 1, 1, 0, 1
  4. It shows the current region code
  5. Push 0 on the remote for region free
Bush 2001 / 2020 / 2026 / 2029 / 2035XI / 2038 / 2042 / 5020 / BTV213DVD / DVR3000 / DVRS01 / PDVD0707 no known hacks
Unblock region code block for Bush BDVD 8310
Hi
You have to flick the on/off switch (which is on the side next to the volume control) towards the back of the machine then it charges. The switch has 3 operations.... towards the front is on, in the middle is off and towards the back is charge...
3helpful
Bush LY1911WCW unlocking code - to make multi region - I have checked lots of sites and none have this TV/DVD combo listed
Please can you help me of BUSH LY1911WCW region code and been try to dvd works but been watch the dvd had just half way and stop and why???
Region unlock for bush 2041
Press Open tray.
You will now be in the manufacturers settings
Select the required region, by pressing Enter. The region will be shown at the top of the screen; 1 = region 1, 2 = region 2; etc; 9 = multi region
Press Close tray
this is for a 2040 .......you never know.
Dvd region code bush 2048
This is for 2047 and could possibly work.
Power up - display is only via TV screen.
Open
Setup
Go to preferences by use of Left/Right arrows
Press 2, 8, 1, 2 in sequence.
Popup appears showing region and SW version.
Use up and Dn arrows to select region 0 for multi region.
Press setup to exit the menu.
Press open to close the tray
Player appeared to remember the setting after powerdown.
This is for 2040 +2045
  • Press Open tray.
  • Press 2, 8, 1, 2 and Enter
  • You will now be in the manufacturers settings
  • Select the required region, by pressing Enter. The region will be shown at the top of the screen; 1 = region 1, 2 = region 2; etc; 9 = multi region
  • Press Close tray
  • 0helpful
    2answers
    BUSH DVD2038
    Try this it worked for me!
    Bush 2038
    1. Press OPEN
    2. Press PROG
    Top Bush Televison & Video Experts
    matt martin
    matt martin
    Sean Wright
    Sean Wright
    john h
    Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
