Cartrigde leaked ink to bottom of printer
How do I open the bottom of HP Officejet K 80 to remove the ink?
Posted by info17075 on
Anonymous
    Novelist:
  • 103 Answers
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 27, 2009
Anonymous
    Problem Solver:
  • 27 Answers
Cannot open bottom, mfg so you can't. throw machine away(sorry)
Posted on Aug 26, 2009
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
2answers
My HP J4580 will only print color. How do I fix it so the black will print?
When you go to print out the document make sure you have selected to print in black and white
Ink leaking in HP 8500 A909G printer
for this you have to strip the printer. your wast tank is full. you can take it out and clean it whit worm water. hope this will help
I can't print anything off the computer since I put in a new cartrigde.
Now way related to cartridge &Printer driver, check USB cable,reload drivers once again.
Cartridge error,refer to devise documentation to troubleshoot
Hello
Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridge and use a clean, lint-free, dry cloth to gently wipe the contacts.
Wipe from the top of the contact to the bottom. Do this for each contact.
Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
Turn on the HP printer, open the cover and remove both the black and color cartridge. Close the cover.
Remove the power cord from the outlet and disconnect the cables running to the computer and/or router. Wait one minute, and then plug in the power cord and then the cables.
Open the cover and install the black and color ink cartridges. Turn the printer on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, you will need to buy new ink cartridges. Office Max or Wal-Mart have ink cartridges for almost every model of HP Deskjet, Photosmart and Officejet printers.
1helpful
My catrige has a error
Wipe Down the Cartridge Contacts
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move onto Section 3.
Reset the HP Deskjet and Photosmart Printers
Turn on the HP Deskjet or Photosmart printer, open the cover and remove both the black and color cartridge. Close the cover.
Reset the HP Officejet and HP PSC All-in-one Printers
Turn on the Officejet or PSC all-in-one printers.
Unplug the power cord from the back of the printer and wait one minute.
Plug the power cord back into the printer. Press the On button and hold until printer turns on.
Print a test page to see if this has fixed the problem. If not, you will need to buy a new color ink unit at any office supply store such as Office Max.
It seems like the printer is not happy unless it prints a cartrigde align page...A LOT!
Reseat BOTH ink cartridges. You might have one that's not making perfect contact.
2helpful
2answers
Changed black ink cartridge and now the carriage won't slide-just keeps hitting something that stops it right where the carriage goes to change ink cartridges. mrsgrdng8
It sound like you may not have gotten the cartridge installed correctly. Remove and re-install the cartridge and see of the problem persists. If it does remove that cartrigde and install the old one and check again. This will determine whether the problem is with the printer or the new cartridge
Ekse
