Question about Sony DVP-CX850D DVD Player
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
My Sony dvd player wont read dvd- disc's burned this week but will read the dvd- disc's that were burned last week. It reads "Cannot play disc" when attempting to read the movie. My other sony 5 disc dvd player in other room reads the burned DVD- disc's that were made this week. The Sony 400 disc plays the DVD's that are in the carosel from last week with no problem and carosel seems to be working fine. What is the problem?
  • Anonymous Mar 29, 2014
    what do T19 mean on my dvd player will not play disc
Anonymous
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Posted on Aug 20, 2009
Can not get dvp-cx995v into hdmi output
Sony has a new firmware release to resolve this issue.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=2824&mdl=DVPCX995V You can download it from this site along with the instructions
Dec 03, 2010 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V "cannot play"
you can clean the motor by the back side
Oct 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
SONY DVD-CX995V "cannot play"
In that symptoms optical block (lens) sounds defective and requires replacement.
Let me know if you want to replace optical block by yourself to provide you more technical info.
Aug 14, 2009 | Sony DVP-CX995V Multi-disc DVD Player
My sony dvp-cx995v
Seems optical lens of unit is causing problem of No Disc.
Clean optical lens with cleaner disc and then try to play dvd.
If still same problem, take unit to local repair shop for fix.
Feb 12, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
Jan 22, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Sony DVP-CX995V
Its problem of incomplete unloading of CD tray so system control in player sense it and generate command to close it.
CD Loading mechanism needs service and cleaning to loading belt.
If you have electronics experience, you can make it easily. let me know if you need further info.
Nov 20, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Hdmi output
There is a firmware update available from sony that appears to address this problem. Go to sony and do a search for the model number dvp-cx995v. I have not tried it myslft but the write seems to address your problem.
May 04, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V will not play through the hdmi output
There is supposed to be a firmware fix for that from sony.
Feb 08, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX850D DVD Player Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
