Re: UNABLE TO ADJUST THE SCREEN ALWAYS SHOWING MENU...
When you press power button press continues F8 key then you see safe mode and other menu enter in "ENABLE VGA MODE'
then go to dispaly property and settings then change screen resolution to 1024.768
then apply and ok.
The option for duplication of the screen is not a hardware related it depends upon the platform/software you are using. Windows from vista(Grid vista) onwards provide a built-in feature to handle multiple screen. I suggest you to update your video drivers and try running the windows file integrity scan this will diagnose if there any configurations files are corrupt.
Use the Menu Button on the enter into the Monitor menu setting.
Select the horizontal or vertical adjust menu depending on which is the one affected and press the menu to select it.
Adjust till you get the correct position using the +/- button. Press the Menu and scroll to exit to quit the setting menu.
Hi :) I had the same problem and i found the solution ..... Press and hold the menu button on your monitor for 10-15 sec . Now ..... have fun :) Rate if was helpful :)
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
In v7.xxx software version, (you dont tell wich you have);
If all menu options are showing:
tap screen, tap Change Pref., tap right arrow to page 8/8, adjust time....
If not all menu options are showing:
tap screen, tap Change Pref., tap right arrow to page 3/3, adjust time.... While your there, tap Show all menu options.
