Question about Epson STYLUS R230 InkJet Photo Printer
Prints only on left side of page.
My new HP deskjet F2280 prints web pages and emails (OE) on left half of page. Word docs print OK.
Posted by bjmcg on
Anonymous
  • 555 Answers
In printing web pages and email please try to check also the print setting before you print the page cause word document files and web pages are not the same in there printing setting. Web pages and emails has different setting so my recommendation is that when you print email and webpages next time then please check the printer settings then modify it the same settings as you wish or as your word document's output.
Thanks
Posted on Aug 18, 2009
How to install the DESKJET F2280, can't find the installer disk
Access the manufacturer's web-site: http://support.HP.com
Enter the model-number, and do the search.
Select the Operating System that you are using.
Download the printer's device-driver.
Install it.
Print a test-page.
Jun 04, 2011 | Office Equipment & Supplies
When I send my job to the printer. The printer will print but only on 1/2 of the page. it looks like the printer think i want two sheets on one page
Is the whole page you want printed on half the page is just half the data printed? If the whole page is printed on half the paper then the problem is software. If the page only prints the left side or the right side blank on the other side then the problem is most likely the fuser assembly. Can you take a picture of the page and email it to us, we will email you back with what needs to be done next.
[email protected]
Apr 30, 2010 | HP LaserJet 2300 Printer
I just purchasea a new internet provider called Frontier I was formally with AOL dial-up. My problem is when printing emails on Frontier, a dark gray background appears, the text is reduced in size and I'm...
Not familiar with Frontier...most email programs has a "print view" option...if not try highlighting by click & drag across what you want to print, click file at top left,print, selection,ok
Mar 20, 2010 | HP DeskJet 940c InkJet Printer
When trying to print up an email message ,it only prints half of the page
pleace disconect the power cable from the wall outlet the press and hold the power botton for 20-30 sec then restart and try to print test page
if still it not work then follow this instrution mention from the below URL
HP.COM/GO/SMARTWEBPRINTING
and install it and then try to print it should print
even after that if it does not print try and add a printer (deskjet 990c) from the printer page
follow the instructions
1.go to the printers page
2.click on ADD A PRINTER
3.click next
4.select local printer
5.afetr that select HP from the left side
6.select deskjet 990c from the right colloumn
7.click on next
8.click on next
9.after that it will prompt to print a test page and set the printer as default (yes)
10.if the test page prints out
11.try and print the e-mail
it should work
get back to me if you still have problem i will help you
dont forget to vote for me (sincerely be appreciated )
Thanks
Regards
Hamid
Feb 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
HP Deskjet 6980 Printer. prints on half page
you'll need to reset the print mode to single-sided, also check the print/text size
Oct 25, 2009 | HP Office Equipment & Supplies
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
I keep getting a test page before printing my doc or picture
To resolve test page prints every time issue, perform the steps provided in the below webpage:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065136&cc=us&lc=en&dlc=en
Now, perform the steps below to change the settings from last to first page:
===== From the HP Solution Center software =====
1. Open the HP Solution center.
2. Click Settings--Print Settings --> Printer Settings
3. Click Advanced Tab.
4. Under layout option select the page order from "front to back".
5. Click OK and try printing.
From application
a) Select tools
b) Goto Options
In that select print tab
c) Check the Reverse Print order option.
d) Click Ok.
Apr 17, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
Epson STYLUS R230 InkJet Photo Printer Logo
356 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
