Mitsubishi tv model # wd-52527, lamp light flashing,no picture.
Tv model # wd-52527,wd-62527, when you turn on the television you only hear sound and the screen is black. The lamp light on the front of the tv is flashing, is the lamp burn out.
Posted by luismelendre on
Anonymous
  • 556 Answers
I would say so.
Posted on Aug 18, 2009
  • michael_j346 Jan 05, 2011
    Yes, the lamp has gone bad! The new lamps usually run around $125.00
    I hope this was helpful...
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Cannot figure out how to connect my new sound bar to my older TV
Use a high speed HDMI cable form the TV to the sound bar. HDMI cables carry sound as well as picture signals. Refer to your TV's user manual http://www.hdtvsolutions.com/pdf/52527-62528.pdf
and the Samsung product support page http://www.samsung.com/us/support/owners/product/HW-F450/ZA for assistance
Mitsubishi wd 62527 blinking status light what can I look at? No Picture, Flahing TImer light goes off agter 2 min then tv turns off and if you power it on it flases Lamp and Status multiple times?
This is a common issue with bad capacitors in the TV. You can call in a shop or repair it yourself. You can google the parts using this number Z1234TV
1helpful
3answers
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a [email protected] for lamp. hope this help you out,
Lamp light is red
pull lamp from unit and investigate it for integrity
1helpful
Tv 62527 light goes off when after a few seconds when turned on
This is generally a Power Supply problem, usually the SMPS so it's replacement or repair.
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Ekse
