Motorola Mobility Blnc Bluetooth Car Kit Portfolio Ihf1000 Logo
Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just paired a blackberry tour with my motorla ihf1000 carkit bluetooth. When a call comes in and i press the green button the caller can't hear me and i can't hear the caller. If i press the green button on my phone it works. Outgoing calls are no problem.
Grand Canyon Tech
Level 3:
  • Master 3,867 Answers
  • Posted on Aug 18, 2009
Grand Canyon Tech
Master
Level 3:
Answers
3867
Questions
Helped
1176435
Points
12717
You going to need to check with RIM the manufacture of the blacberry there are certain devices that do not work well with the unit and this maybe one of them.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
Level 3:
  • Master 630 Answers
  • Posted on Jan 30, 2010
Anonymous
Master
Level 3:
Answers
630
Questions
0
Helped
204592
Points
1976
On mine I press the blue M button to answer the calls
I can't pair an iPhone 13 with IHF1000 Bluetooth.
Pressing Search on the iPhone is only half the task. There is a button on the IHF1000 that also needs pressing straight after. After they shake hands, you enter the PIN code. The button often has a the Bluetooth symbol on it.
https://www.fixya.com/support/r26362721-pairing_bluetooth_devices
Even the articles here miss it! It is not the way Bluetooth works, or you could pair to every device around you.
Here it is in the Manual
https://www.manualslib.com/manual/2174663/Motorola-Ihf1000.html?page=18&term=pairing&selected=1#manual
Press and Hold
Press and hold the TALK button to initiate the pairing
process.
https://www.google.com/search?q=motorola+ihf1000+pairing+to+iPhone
tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
tip
How to pair a Plantronics Explorer 245 Bluetooth headset and a BlackBerry Tour
The Plantronics Explorer 245 headset can be paired with most Bluetooth-capable phones and smartphones to enable hands-free phone conversations. To pair the headset with a BlackBerry Tour, follow the steps below:
Make sure the Plantronics headset is off before trying to pair the two devices. On your BlackBerry, scroll down to Manage Connections (the antenna icon) in your Home folder and click the trackball. From the list of connections, select Set Up Bluetooth. The Add Device box will appear, asking if you want to search or listen for a Bluetooth device.
At this point, turn your Explorer 245 on by sliding the on/off switch toward the microphone end of the earpiece. Once the device powers on (if you have it in your ear, you'll hear a few short tones) you should see repeating red and blue flashes from the LED lights on the side of the headset. If you only see blue flashes, hold down the call button (the side button) for a few seconds, until the lights start flashing red then blue.
Now, on your Tour, select Search. Bluetooth will be enabled if it's not already, and then the BlackBerry will search for nearby devices. When the headset appears on the list of devices found (it should read "245Plantronics" or something similar) select it. A box will appear letting you know that pairing is now complete, and asking if you want to connect to the headset. Select Yes.
Your BlackBerry Tour and Explorer 245 are now paired. If at any point you turn the headset off, turn the BlackBerry off, or turn the BlackBerry's Bluetooth feature off, the two devices will automatically reconnect when they are able. When you look at your list of paired devices on the BlackBerry, the Explorer headset will appear in bold to show that it is currently connected.
2helpful
I don't have the "numeric key" for a hook up to my
pin code is 0000, make sure you put the device into pair mode before hand. To do this :
with the device off, hold down the green button until you hear a language loop. When you hear the language of your choice, let go of the green button and press it once right away. You will hear a message about your phones bluetooth menu, when you hear that go back to your blackberry's bluetooth menu and when you enter the pin code 0000 it should work.
Rylan
Can't answer calls using IHF1000 when paired with my iPhone. Green button just hangs phone up..
Press the big blue button in the middle. It will take the call but you have to wait a couple of seconds. Don't answer the call with the phone though as it will not transfer to bluetooth (it's a sort of privacy option)
1helpful
What to do
If you are sure that the handsfree system in your truck is an IHF1000, then long pressing ( >2s ) the center "talk" button on the IHF1000 will put the system into pairing mode. Follow the instructions that are spoken from the kit - have your phone scan for handsfree devices then, find the IHF1000, select it, then enter "1234" for the passcode and complete the pairing.
14helpful
Can not pair with my new Blackberry storm - Help???
Make sure the BlueAnt Supertooth 3 is turned OFF.
  1. Press+Hold the Volume Up button and then also press the green button to reset the unit.
  2. After completing the above reset, turn the ST3 OFF again and wait at least 10 seconds.
  3. Turn unit back ON and select language when prompted.
  4. Follow the voice prompts and pair the ST3 with your blackberry as normal.
  5. After pairing has completed you will hear the ST3 announce “loading phonebook – please wait”.
When your blackberry ask your permission to allow bluetooth to connect and donload phonebook allow it permanently.
1helpful
People can't hear me on my Blackberry Curve unless I turn the phone and talk loudly right into the speaker. I am so sick of having the "I can't really hear you" conversation! With my bluetooth, I have the...
When using the IHF1000 with your Blackberry Curve, I recommend to go into the device properties for the IHF1000 in the phone's Bluetooth devices listing. Under that, there should be a phone setting to turn Echo Canceller: On, Off, or Automatic. By default, it is Automatic. For this phone with the IHF1000, I would set it to Off. This has solved audio quality problems for a number of people.
Note: this may or may not directly address the low uplink audio level you are experiencing, but it does seem to help with general call audio quality when connected to the IHF1000.
MOTOROLA IHF 1000
You need to pair the carkit with your phone. Make sure the Bluetooth feature on your phone is set On, then follow the Pairing process outlined in the user manual.
3helpful
3answers
Code for bluetooth car kit
Also note that some of the IHF1000 carkits may also use 1234 for the passcode. When you go into the Setup Menu and ask it to Pair a Phone, the prompt will tell you the correct passcode (0000 or 1234) to enter by saying, "Enter xxxx, when requested".
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
