Question about Lowrance GPS
Can i use a SD Card from a lowrance in my 7" Axiom
Posted by John Mathews on
4 Related Answers
Anonymous
  • 66 Answers
SOURCE: How large of an SD card will a Lowrance IFinder
iFinder is the king of GPS devices with respect to memory. Though 1 gb looks a little bit too much for it in the time being and may well hang the phone .
You can purchase MMC cards with up to 128MB or SD cards with up to 64MB of memory
Hope this helps
Posted on Mar 07, 2009
Anonymous
SOURCE: Need a fully working Lowrance 250C GPS Sd card
I have had a similar problem and founf this site where you can get a new card that will work for your GPS. Info, pasted below:
The Nextar GPS-MAP09SDC SD card with updated navigational maps and information has a MSRP of $69.99. Please visitwww.nextar.com to purchase the map upgrades and for more information on upgrading your maps.
Posted on Oct 21, 2010
TO Lady
  • 638 Answers
SOURCE: The Lowrance 3500C has a
No, this means the internal memory size is 1 GB. If this unit accepts SD cards, you can increase the map capacity. 2GB SD cards should work properly in the unit.
Posted on Nov 01, 2010
Anonymous
  • 1098 Answers
SOURCE: i I understand i can upload date to a sd card
Hi there.
Prerequisite: Java must be installed on your computer for the installers to operate. If you do not already have a Java JRE or JDK installed, please visit the Java website.
Installation Instructions
  1. Make sure the MMC/SD card reader is properly connected to your computer (and, if necessary, that the drivers are installed).
  2. Insert an MMC/SD card with at least 8 MB of free space into the MMC/SD card reader.
  3. Click on this link to go to the installation web page.(click on INSTALL THIS UPDATE....)
  4. Wait for the Java web installer to download and run. Follow the Lowrance update installation instructions. If you are not sure about a step, just select the default choice. When the installer finishes you will prompted to click Finish to exit.
  5. Turn your Lowrance GlobalMap 3300C unit off.
  6. Place the MMC/SD card containing the updated operating software in the unit's MMC/SD card tray.
  7. Turn your GlobalMap 3300C unit on. The software update will automatically install.
Let me know if you need further assistance.
Thank you!
Posted on Sep 04, 2011
How do i move photos and videos from micro sd to samsung galaxy axiom
sometimes it is not in photos,, it can be in removable storage or storage..there maybe a settings pull down once you get to removable storage.. are you sure you moved all photos from the old phone to the sd card before you transferred it to the galaxy? Does you galaxy phone have enough internal memory to store all photos from sd card>
Why didn't my Navionics gold card download work?
Your running an elite 7. It's not compatible with navionics platinum.
1helpful
If I get a new Lowrance GPS, can I use my SD card from my ifinder Hunt in the new device and use all my saved points?
First use "add gps" and add the original unit and the H20
use "receive from gps" to call in the original waypoint file from your sd card
use "send to gps" to save the new waypoint file to the sd card
remember that the original gps file may contain more waypoints than the H20 can hold so you may have to delete some waypoints from the file while in EasyGPS
if this is not clear enough, let me know and I will try again. I use the program all the time.
I just realized I left something out. EASYgps does not like the Lowrance HDS File version so an extra step is required if you are transferring files from an HDS to an IFinder. Save your HDS waypoints as Version 3 to the SD card and EASYgps will accept them
1helpful
HOW CAN I GET A JEPPESEN DATABASE UPDATE FOR MY LOWRANCE AIRMAP 600C?????
Go to LEI Extra and pay US $49 plus $20 or $30 and then the availability ceases in July 2011.
Navico/Lowrance are leaving everyone without support. So much for supporting the undergod and trying to encourage competition.
I will say that I have had 3 Lowrance Airmaps and found them much more suitable to my needs than the Garmin handheld although I have 2 x Garmin 430 GPS in my aircraft.
Finally, for me in Australia a one time Lowrance SD card upgrade will cost not only US $49 but I think another US$50 postage. Carrying a Lowrance SD card is about two times more expensive than two hard drives.
Dec 14, 2010 • GPS
The Lowrance 3500C has a 1 GB capability. Does that mean I must purchase a 1 GB SD card for it? Can't find anything smaller than a 2 GB SD card, but will a 2 GB card cause problems?
Need a fully working Lowrance 250C GPS SD card or a copy of the same.
Just bought at auction. No manuel.
My apologies. I see now that you have an iWay 250C. Here is the manual as found on the Lowrance website.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/iWAY250c-manual_0160-201_080706.pdf
2answers
Loading Maps
MapCreate Topo does not have lake maps. There are 'some' maps on Lowrance's web site (Free Enhanced Lake Maps) but you may need to purchase lake maps on SD cards for the area you're interested in.
Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Map loading from SD card
Yes go to the Lowrance web site and down load the fix to a sd card , put the sd card in the i finder and it will update it automaticlly. I have not done it for map create 7.0 but have for map create 6.3. On the web site look under suport or downloads and you should find it. There is also a lot of free lake maps that you can download to sd card also. Good luck
budman630
GPS Logo
Top Lowrance GPS Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
