There is no update for the DMC-LZ2 available If Panasonic has new firmware for any camera, it will contact all registered owners and tell where and how to get and install the update.
Be aware, you only can update a correct working camera. There is no way to update a camera that does not function for 100%
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
You can download a manual from the manufacturer's web site at http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-LZ2
First of all, you should forget about using the internal memory...it just causes problems (as you can readily see). Always use a memory card. If any of the pics on your camera are important, you should download them to your computer before continuing. Then, go into the menu and find "reset"...follow the on-screen instructions. Then, with the card out of the camera, go into the menu and find "format"...follow the on-screen instructions. Then insert a blank memory card and go into the menu and find "format" again...follow the on-screen instructions. From this point on, your life will be wonderful.
Solution: Turn the camera on. Put it into camera mode so the lens
opens. Then push up on the underside of the lens, you'll see the screen
light up and it can now take pictures. This worked for me for a month
or two. The problem is that I have to keep pushing harder and harder to
get it to turn on, and now it turns back off as soon as I stop pushing.
So I have to get a new camera. This is a widespread problem with this
camera. I previously paid Panasonic the $162 to fix the zoom freezing
up. I'm not paying again.
Dan
I had the same problem. So I figured I'd take it apart and see what was loose. I removed all the screws around the outside and pulled the back cover off. There is a ribbon connector at the top with a locking cover. The cover was unlocked. I re-seated the ribbon connector and closed the lock and it works now. Let me know if you need more details.
